Brakes Squeal Horribly? just got new pads?
Old Mar 26, 2003 | 02:25 PM
bobjohnson's Avatar
Blazin......
I put Raybestos QS pads on my car about 4 months ago, they were ok but in reverse when i stopped i had a bad squeel.
Now, when i drive forward all the damn time, it squeels horribly, its loud and it sounds almost like a pad is loose or something is grinding. onthe highway you cant reallly hear it im assuming its just too loud or the high pitch noise it too high.
Someone please help, im at work all night and got class in the morning so i guess im driving my crap like this for a while, unless you people can help me.
Old Mar 26, 2003 | 03:15 PM
bobjohnson's Avatar
Blazin......
Re: Brakes Squeal Horribly? just got new pads?
you people ever change your brakes.??
Old Mar 26, 2003 | 03:21 PM
slop00's Avatar
Did you change all 4 brakes? I had to get new back brakes because they were doing the same thing. They would squeak until I got up to a higher speed. If you changed all 4 I would check the caliper, you could have a caliper sticking. That could explain the brakes stopping squeaking at higher speeds because the caliper finally releases fully.
my 2 cents
Slop
Old Mar 26, 2003 | 03:36 PM
4drsc's Avatar
Have you tried jacking it up and rotating the wheels individually to see where the noise is coming from? It might be an anti-squeal shim that worked loose and is now contacting the rotor...
You need to have a look at it and not just drive around with it making that noise... It might be minor or it might be something that could cause you to lose control of your car. Its hard to tell what the noise is like when we can't hear it or look at the car...
Good luck,
Jim
Old Mar 26, 2003 | 03:50 PM
bobjohnson's Avatar
Blazin......
Re: Re: Brakes Squeal Horribly? just got new pads?
Good luck,
Jim
thanks jim that makes good sense, now i just gotta wait till i get off work at 10 to try something. worksucks
Old Mar 26, 2003 | 04:52 PM
99maxi's Avatar
do u get noise when u are driving? or braking?
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
