changing corner bulbs
i'm trying to change my corner bulbs, the one that next to the main headlight.
my question is after I took the screw off from the top of the housing, I try to pry it open like the manual says, but there is a socket like thing at the back, no matter how hard i pull it won't come off.
am i doing anything wrong or i have to keep pulling harder??
thers a ball in the back of the light thats snapped in a socket which you have to pop out of to remove the corner light. I was able to change the bulbs without removing the light because I didnt want to remove my eyelids. you have to take out the turn signals and its really hard to reach up and I got a few cuts to prove it.
Originally posted by masterB
the ball socket is like impossable to pop out..
shove a flathead in between the headlight and the parking lamp(preferably with some cloth on it to prevent damage) and then put shove the flat head on the other side and pry it out a bit more, and then with a firm and even grip on both sides - RIP it out, but make sure its even pressure, cause if its not, your going to break the mount on the back........again your going to have to put in ALOT of force into it
Originally posted by Max-2-GTR
just get a flathead screwdriver inbetween the socket ball and where it's in and turn the screwdriver, the socket should pop out by itself
if u try to pop it off using the nissan instructions or if u try to pry it off with the flathead screwdriver u'll end up damaging the corner light..
JoshG
51
Sep 21, 2015 10:41 PM
