Rear Brake Pad Replacement
Old Mar 30, 2003 | 03:10 PM
RobMatera's Avatar
Anyone have a how-to for rear brake pad replacement on a 1997 Maxima SE. I've done the front, but the rear looks a bit more complicated. A link to some instructions would be most helpful. Thanks.
-Rob
Old Mar 30, 2003 | 03:57 PM
gtr_rider's Avatar
192.168.1.1
I'll make one in a little bit
Old Mar 30, 2003 | 04:27 PM
njmaxseltd's Avatar
It's basically the same process only you need to twist the piston to get it back in. Don't force it with a C clamp, it wount move and you'll damage it.
I used a good sized needle nose plier to grap the nubs and turn it clockwise. (to the right)
Make sure the dust cover doesn't get hung up when you turn it.
Old Mar 30, 2003 | 05:56 PM
MAXIMARK's Avatar
not tearing the piston boot...
... I am in the same (brakerebuilding) boat - except I am wanting to do a full rebuild on all four calipers. Anyone know of a site that has a "how to" on caliper rebuilding? When I tried to turn the rear piston in the piston boot got all wound up. Is it connected to the piston? My impression is that it is tight in the bore (caliper) and that it is supposed to allow the caliper to turn when everything is working properly. My (1995) calipers have never been worked on and there may be some corrosion at the piston boot connecting point - I wonder what the insides will look like when I tear them down for a rebuild. I have seen a number of posts suggesting Motul 600 brake fluid - is this the best brake fluid to use? Brake Safely, Mark V.
Old Mar 30, 2003 | 10:27 PM
Lushka16's Avatar
Re: not tearing the piston boot...
I JUST finished with my rear brakes, it's really easy. Disconnect the two bolts holding the calipers on. Replace pads. You can get a tool at Autozone for twisting the pistons, or you can use the needlenose pliers. I had a REALLY had time turning mine, so I completely disconnected the calipers and carefully took some huge pliers to them. Also, I first removed the piston by twisting it all the way out. I took the rust off it with some derust stuff and very fine sand paper. When I put it back it (after fiddling with the stupid boot for 20 mins because it's tight, and it's not supposed to twist with the cylinder, btw) it screwed very easily. Screw it all the way back, re attach calipers to brakes, and you're done. Probably a good idea to bleed the system while you're at it.
-E
Old Mar 31, 2003 | 08:17 AM
phenryiv1's Avatar
Mod her. Ate her.
Is the Hayne's writeup on this helpful?
Old Mar 31, 2003 | 08:35 AM
mahk's Avatar
The Haynes manual does an excellent job at describing this process. I had a caliper go on Friday and by the time I was able to fix it had ruined my router. I followed the Haynes manual step by step and it took me less than an hour from taking the wheel off to changing the caliper and router to bleeding the system, back to putting the wheel back on.
Mahk
Old Mar 31, 2003 | 08:38 AM
mahk's Avatar
Oh yea, the tool for turning in the piston from AutoZone makes your life sooo much easier. I do recommend dropping the 10$ for this. It will probably save you from a bloody knuckle or two.
Old Apr 30, 2003 | 09:17 PM
tvn_1010's Avatar
hi,
just wondering if you got a chance to make one. if you did, can you point to me where it is located. thanks.
**i checked the faqs and couldn't find it there.
Old Apr 30, 2003 | 09:31 PM
AlanHoskins's Avatar
The dont lend it to you free where you are? Here you just give you drivers license number then you get to borrow the tool for a hour or so.
Old Apr 30, 2003 | 11:31 PM
Chunger's Avatar
My other car is a Hybrid
If you still need it...
Clicky Clicky
Old May 1, 2003 | 07:25 AM
StygianMax's Avatar
Check out motorvate.ca The process detailed there is for the front caliper but it's not that different with the rear ones.
Old May 1, 2003 | 07:34 AM
breaux124's Avatar
I second this! The tool is easily worth the cost, makes life SO much easier.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
RealityCheck
Aug 5, 2015 06:18 AM
