rear oxygen sensor removal
Old Apr 2, 2003 | 12:36 AM
1slowmax's Avatar
Can anyone tell me what size wrench I'll need to remove the rear oxygen sensor on a '99 GXE?
Thanks.
Old Apr 2, 2003 | 04:59 AM
fisher01's Avatar
Re: rear oxygen sensor removal
Thanks.
I just did this about 2 months ago on our 99 GXE. You need a special 02 socket removal tool for the rear sensor. Because of its location theres no way you can get any type of wrench on it securly enough to even turn it. I used the free loan tool program at Autozone for the 02 socket. Once I had that tool, it took about 5-10 min. to replace the sensor. To purchase a series of O2 sensor removal sockets at Autozone runs about $20.
Old Apr 2, 2003 | 05:36 AM
davey6693's Avatar
I used an open-ended long 22mm wrench. That will work too.
Old Apr 2, 2003 | 06:04 AM
fisher01's Avatar
On my 99 gxe the O2 sensor is located on the top side of the exhaust pipe and is actually slightly indented. I tried a variety of 22 mm wrenches, but none of them could securely grab the sensor without the risk of stripping the nut. To be safe, I would highly suggest the 02 socket tool.
Old Apr 2, 2003 | 12:14 PM
Slowpoke's Avatar
Re: Re: rear oxygen sensor removal
What do you mean a "series" of sockets? I thought it was a one-size-fits-all kind of thing.
What is the free loan tool program? Does it require you to buy the replacement sensor at Autozone?
Old Jun 15, 2003 | 03:07 PM
DR-Max's Avatar
Not sure what year your Maxima is but on my 95, the rear O2 sensor needs 17mm wrench, 22 is too big.
Old Jun 15, 2003 | 05:01 PM
drageron's Avatar
nah its easy if you put a little nut into it with a 22mm wrench but i wound up using a cresent wrench and got the ****er right out, its a simple procedure once you get into it but there right its in a %itch of a spot
Matt93SE
May 24, 2019 02:58 PM
Huttig2009
Sep 25, 2015 03:31 PM
Maxilano
Aug 31, 2015 07:33 PM
doobadoo
Aug 15, 2015 06:43 PM
