how to instal an engine coolant temp sensor
Old Apr 2, 2003 | 11:39 AM
korupter's Avatar
blah, search feature no worky for me... anyone know how to instal a coolant temp sensor for a 95 max?
Old Apr 2, 2003 | 11:43 AM
Jepht20's Avatar
Custom User Title...
well if you know where it is, it's as simple as taking out the old one and putting in the new one. i think you're supposed to drain the coolant a little or else it splatters out everywhere. when i did mine, we just took the old one out and put the new one in fast and added some coolant to make up for the amount that came out. i think the chilton's and haynes have decent diagrams to doing it. sorry if this is too general, but that's really how i'd describe it. goodluck
Old Apr 2, 2003 | 12:02 PM
Jamsan's Avatar
It's general because that's all there is to it...Unscrew the old one, screw the ne....OMG look at all this coolant spilling...*watch amazed* NO...keep screwing the new one back in....the quicker the better...Add a little coolant when your done to retain what you lost, and that's all there is to it...There's some pictures of it in the Hayne's manual, or if you want when I get home (~5ish), I'll get the pictures up I took when someone needed this no less than 2 weeks ago
Old Apr 2, 2003 | 12:08 PM
hacim105's Avatar
follow the upper radiator tube to the engine. There are 2 sensor looking thingys. The second one(furthest from the front of the car) is the ECT sensor. Unhook the eletrical connector unscrew the sensor and put in the new. I never drained any fluid or anything. I never had a problem with coolant going anywhere.
I don't understand why anybody else has had coolant fall out of the engine.
Old Apr 2, 2003 | 01:26 PM
korupter's Avatar
thanks guys, i found it. I think little or no coolant would come out because the sensor is on the top.
Old Apr 2, 2003 | 02:15 PM
Jamsan's Avatar
you'd be surprised...
Old Apr 2, 2003 | 03:07 PM
Mishmosh's Avatar
Supposedly, you aren't supposed to use an insulating seal tape like the teflon tape commonly used for sealing pipe threads. Do you use nothing or is there something specifically that serves the sealing purpose but does not interfere with the sensor function?
Old Apr 2, 2003 | 03:30 PM
redmaxpa007's Avatar
i SeE what you did therE
the tape goes on the threads.. how would it interfere?
Old Apr 2, 2003 | 03:53 PM
korupter's Avatar
yes! I got a coolant temp sensor from Tustin Nissan in cali for $22 (you guys rock). And yes, coolant did come out, but with my cat-like reflexes; i shoved the new one in quickly. The electrical connector was sort of hard to remove, but all in all, it was easy. Thanks for the replies... no more running rich and unexpected stalls for me
Old Apr 2, 2003 | 04:15 PM
korupter's Avatar
btw.. does anyone know the part # this? I threw away the package it came in...
Old Apr 2, 2003 | 04:22 PM
i have one sitting in the car.. i will get it and let you know tomorrow morning
Old Apr 2, 2003 | 04:59 PM
Mishmosh's Avatar
I dunno if it's grounded in any way through the threads. I read a few posts before that said their Chilton's or what have you said not to use insulating tape. He put anti-seize on the threads instead but I don't know if that's right. Looking at it, the connector has two leads so I think you're probably right...it doesn't matter.
ECTS:
"SENSOR ASSY-TEM
22630-44B20"
Justinmc760
Aug 23, 2015 03:10 AM
FlaMark
Aug 20, 2015 12:17 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
acw
Aug 13, 2015 12:50 AM
