Y-pipe installed, reset ECU?
Old Apr 3, 2003 | 08:43 PM
DJSmitty's Avatar
I hate asking this, but search is gone.
I just got my Budget y-pipe installed today (after having to see it in my closet all winter).
$30 at Monro Muffler Brake & Service on East Main in Rochester, guy named Bill. Great price.
Anyways, it sounds fine, and I can't test the performace until this freezing rain is gone, but I'm wondering if an ECU reset is a good idea, or if the ECU will adjust by itself over the next week.
Is the learning process done all the time for exhaust sensors etc, or just when it is reset?
Cliff notes: New y-pipe, reset the ECU?
-Smitty
Old Apr 3, 2003 | 09:29 PM
Ramius83
Yes, it is best to reset the ECU after most/any power adders/free-ers....
Old Apr 4, 2003 | 04:15 AM
Ceasars Chariot's Avatar
Old Maxima Legend
during the install we unhooked the battery ..and after everything was complete ...we hooked up the power again ... may head unit is like flying a jet, so remember to take down the settings if you do disconnect. anyways ..thats how i reset my ecu ... guess it worked ... the chariot is much faster now
Old Apr 4, 2003 | 05:21 AM
speedemn's Avatar
I don't think that is necessary. Motorvate.ca did NOT reset his ECU after his y-pipe install and dynoed a week later and got +19HP at peak... +31HP at 6200RPM... I'm sure everyone who has a y-pipe here has seen that dyno.
Old Apr 4, 2003 | 06:01 AM
davemax's Avatar
Did adding the y pipe increase the noise level in the car?
Old Apr 4, 2003 | 07:03 AM
speedemn's Avatar
Nope, not at all for me. I got the y-pipe and b-pipe with resonator (and kept my stock muffler). Cabin noise is hardly any different than before.
Old Apr 4, 2003 | 08:33 AM
goldmax's Avatar
Have you noticed a big difference in performance? I would like to do the same...more power but no more noise. Give us your take!
Old Apr 4, 2003 | 09:53 AM
slavik'sMAX's Avatar
I changed my whole exhaust (y/cat/bpipe), leaving the same aftermarjet muffler that I had before, the noise level did increase significantly. But from reading other posts on this, I think that leaving/using stock muffler keeps the noise way down.........
Old Apr 4, 2003 | 09:59 AM
99Maxima5sp's Avatar
theres a nice burble on start-up and i cant tell you if there any difference WOT since all i hear is my intake
eric
speedemn's Avatar
Performance gains are definetly great. If I had to do it again, I'd do it in a heartbeat. I like a quieter, deeper sound, so the stock muffler is good enough for me. I don't mind not having the 1-2HP that I MIGHT gain with an aftermarket muffler (at the expense of a loud Maxima).
So get a resonator on your bpipe and keep your stock muffler and you will be happy.
Old Apr 4, 2003 | 10:35 AM
MChapel's Avatar
...and then add a Budget CAI to top it all off. (same price as the y-pipe)
Old Apr 4, 2003 | 10:41 AM
speedemn's Avatar
I still don't see any definitive gains from any intakes out there... Frankencar claims +10HP on the 2K2... does the same apply to gen 4? Then there's the Ingen and Budget CAIs... don't know if you might actually lose some power with those. Gotta get the jury out on that one.
Old Apr 4, 2003 | 10:58 AM
goldmax's Avatar
Your profile shows Budget y, B and Test. Does that pass emissions? They do ODBII testing here each year as part of getting the tag renewal...just want to make sure it doesn't mess things up. Does any of these replace the pre-cats, etc.?
Old Apr 4, 2003 | 11:30 AM
speedemn's Avatar
My emissions was done in June... so don't have to do another one until a couple of years (is it every 2 years in Canada?) I have my stock cat to slap back on for emissions.
The y-pipe eliminates the pre-cats.
Old Apr 4, 2003 | 11:36 AM
njmaxseltd's Avatar
Resetting your ECU does nothing except erase any error codes. It does not reset any operational parameters.
This info is stated in chapter 6 of the Haynes manual.
If goes even further to say that disconnecting the battery for extended periods of time will erase the general operational parameters of the vehicle and can lead to [b]poor performance[b/] while the ECU relearns everything. It's not recommended to do.
Our ECU is constantly learning, there is never a need to completely reset it to make it learn any changes you make to your engine. It will immediately learn them as you drive.
goldmax's Avatar
Thanks!
Old Apr 4, 2003 | 01:46 PM
DJSmitty's Avatar
Yeah, I looked into that once you mentioned it. The wording is a little misleading when it says:
Clearing the codes will allow the computer to relearn the new operating parameters relayed to the new component.
But it's pretty clear that only applies to a replaced sensor. I always thought that using the screwdriver method on the ECU reset all the engine parameters, but I guess that only happens if you disconnect the battery for a long time.
Thanks for your help!
-Smitty
Old Apr 4, 2003 | 02:06 PM
Smithdogg1's Avatar
I think that its pretty much a myth that resetting you ECU when you get new mods will help out with performance. I really dont think it will do anything for performance. Esp after reading that info from the Haynes manuel.
ballerchris510
Sep 10, 2015 09:35 PM
mix master
Sep 4, 2015 05:50 PM
