Should I get a VI?
Originally Posted by JAY25
and if you have a supercharger with a MEVI, it is so sweet to see that speedo and RPM needle drop so fast it will leave you speechless
, Myself and two other boosted members ran a Evo on the freeway, we punched it around 3k and the evo and myself were neck and neck until about 6K after that I pulled away from him, look on his face priceless because that was third gear in 4th gear boost brought me back to 5KRPM very fast and put about 5 plus carlength on the EVO. The VI is awesome thing for the freeway and boost.
NOW I REALLY want one. Need to save for that SC as well! Anyone in chicago that has a mevi and ECU so i can check it out?
Your car will run fine with a 96 JWT modified 5-speed ECU. You will get a CEL from the rear o2 sensor. It will just be a little annoying having to see the little red light all the time, but it will not hurt performance. The rear o2 sensor does not relay info to adjust air/fuel ratio's, it just monitors the cat.
I am in the Chicago western suburbs if you would like to take a ride in my VI/JWT-ECU 5-speed I30. I would most likely let you drive it as well (being that you don't seem like an idiot)
