Changing the side parking light next to the headlight
How do i change the parking light that is directly next to the headlight it is ver confsn and my hand doesnt fit
Re: Changing the side parking light next to the headlight
Originally posted by SiCkBLaCKMaX99 How do i change the parking light that is directly next to the headlight it is ver confsn and my hand doesnt fit |
it is very simple. all you have to do is pop the hood, look at the side marker light and you will se that it is connected into the front brace. take out that screew and use alittle force to wiggle the light out. it is held in place by a hole and there is a ball on the light that it snaps into. (it sounds alittle confussing, but you will understand when you see it.) after you have the fixture out then unclip the power wires leading to it. this will allow you to completly take out the fixture. then turn the grey round peice that is in the middle of the side maker. once it is turned pull that peice out and there is you light. replace the light and put back together. make sure you snap that "ball" into the hole like i was talking about. aslo be sure to notice that there is lip on the side of the fixture that has to go under a lip on the frame. if you don't put it under the lip then it will not go back in correctly.
it is very very easy and should take you no more then 5 mins tops even if you have no idea what you are doing. hope this helps. good luck chris |
wordjb is talking about the sidemarkers at the bottom above your fog lights. i am not sure if that is what you wanted to do or not. i gave you directions to replace the lights right next to your main headlights. i am not sure what you want to replace. either way you have very good directions for replacing both lights.
Chris |
Originally posted by Blkmax95c wordjb is talking about the sidemarkers at the bottom above your fog lights. i am not sure if that is what you wanted to do or not. i gave you directions to replace the lights right next to your main headlights. i am not sure what you want to replace. either way you have very good directions for replacing both lights. Chris My clearence lights dont want to come out i took the screw out but i am afraid that if i pull harder than i am the light is goin to break help me out i ave a 99 max se |
© 2024 MH Sub I, LLC dba Internet Brands
