cold air intake
Old Apr 7, 2003 | 06:58 PM
skymax96's Avatar
cold air intake
hey guys i have got a problem. well i am rebuilding my 96 se maxima and we got the skyline bodykit and it is ready to put on so i decided to do my cold air intake before i put the front bumper on. so i made my own cai, but now when i start the car it starts up and everything but if i let it idle at all it dies. i can rev the engine and it stays running but the second i let it idle it dies. can anyone help me out.
Old Apr 7, 2003 | 07:15 PM
TheMax95's Avatar
Re: cold air intake
Check all of your vacuum hoses. Make sure they are nice and tight. There are 3 that connect to the midpipe section. Also, check your sensers. There are 2. The MAF sensor and the Air Temp Senser. Make sure they are plugged in correctly.
Do you have a Check engine light?
Old Apr 7, 2003 | 09:21 PM
skymax96's Avatar
The check engine light does not come on. The small vacuum lines are connected, no breaks or lossness detected, however the larger vacuum line that goes from the solenoid, by the back head, to the old black box that was between the MAF and the throttle body we have a small filter on.
Obviously a small cone filter is not the way to go. I took off the filter and the problem remains, if restrict the air going into that hose the car will idle properly.
Old Apr 7, 2003 | 09:48 PM
JsL's Avatar
JsL
piping is too restrictive for the IACV to suck air in???
Old Apr 7, 2003 | 09:51 PM
skymax96's Avatar
If I restrict the IACV it idles properly, if I let it free flow it will not idle.
Old Apr 7, 2003 | 10:45 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
when my MAF sensor broke, the car acted the way you describe yours.
Old Apr 8, 2003 | 01:16 AM
Nismo's Avatar
your saying you have a breather filter on the end of the little tube that leads to the crank case? that will mess up MAF readings if you do
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
hayne
Oct 5, 2015 11:53 AM
Sep 27, 2015 08:37 AM
