Anyone Try Hyper Ground Wires?
I was reading up on an article in "TURBO" magazine, it was about the hyper ground system. I dont know if anyone has heard of this or know what its about. On some cars it shows a big improvement than others but i was just curious as to if anyone has tried out the ground wires on there max. Its a safe and reliable generation tuning system that provides a low resistance ground path. A better ground gives more Torque, better Mileage, better Response,and better Starting Ability.
$100.00
, I thought I saw'em on e-bay for around sixty. Anyway I think if you get some low guauge monster cable and a terminal set it'll be cheaper. I would have done it already but I don't know all the grounding points yet.
. If someone knows I would appreciate a little help.
I think some people just cleaned their existing ground points and saw some benefits. I may try that this summer, maybe add a few extra ground points to help. Spray them so they don't oxidize (sp?) so fast. Some one had posted on here on how they did their own cables and where the ground points were. When the search feature comes back you may want to check for it.
Originally posted by Midknight MAXX
$100.00
$100.00
Re: Well?
Originally posted by maxperformance
any noticable improvements?
and this mod DOES improve electrical efficiency...The Maxima
is poorly grounded to begin with, but, you're really not changing
the engine...
If anything, I think that my lights worked better...no dimming
under load...
hope this helps,
FLO_BOY
do it if you're board. I did it... it seemed to accelerate a bit smoother... but then again i think the real change happened when i took off the bolts on the ground points and cleaned them. After 7 years of not cleaning the engine bay, it was pretty dirty down there haha.
electrical system is the same tho... headlights do seem to dim when i hit the brakes or wind up/down windows and moonroof.
How many and where are the grounding points?
The pic has all grounding points on the Maxima...someone on
here already gave me this pic, so I can now give it back!
FLO_BOY
I'll Post the Pic
Send me the pic and I'll post it.
tranau151@charter.net
Originally posted by FLO_BOY
I have a pic, but need someone to host it...
FLO_BOY
FLO_BOY
any of those bolts that hold the rear seats to the chassis would work... but in you're case you'd have to pull some pretty thick wires all the way to ure engine bay. The point of the mod is to easily spread the grounding... sometimes u provide a direct connection to the engine block so the spark plugs work more efficiently... well i never noticed that much of a difference except smoother acceleration. my electrical stuff was pretty much the same, lights still dim and stuff. good luck.
Import Tuner had an article on this several issues ago. And they happen to test a 97 Maxima SE. It gained 7hp from the wires. A picture of the Dyno results was included. The reason your lights dim when you brake or use the window is due to a bad ground somewhere. I had the same problem and after fixing it my lights never ever dim for any reason.
Actually, the reason the lights dim is because the load its pushing. I bought the Hyper ground kit and followed its directions. My volt gauge does not move as much, but w/out dyno'ing it, have no idea what good it does. But my grounds were: Original to body, and opposite side of engine, but the ground points went from: battery, tranny, intake and head.
Again, the principle is sound, but don't expect much in the way of anything noticeable for gains.
found this digging for info:
> Thanks for your inquiry about the Hyper Ground System. Like you, I am not
> an engineer nor do I claim to be, but what I have seen is that the Hyper
> Ground has shown some type of gain on every vehicle we have tested it on.
> Many of our customers who have bought Hyper Ground have reported a
> noticeable improvement in performance, and we have not heard of anyone who
> was dissatisfied with our product.
> A lot of what this person says definately holds water, such as routing,
> ground points, crimps etc. playing an important role. Because the Sun Auto
> Hyper Ground kit is constructed of the highest quality materials (99.99%
> pure copper, 1477 strands per wire, available 3-layered shielding and gold
> plated terminals) the addition of our kit placed in the best points with
> effective routing should show a noticeable improvement. Also, the inherent
> ground problem that Nissans' in general seem to have will only amplify the
> effect of having Hyper Ground installed. We tested a 97 Maxima, which
> posted considerable gains. The car was a customers vehicle at XS
> Engineering [(714) 698-8300] and had simple bolt on accessories
> (exhaust/intake), left as is for dyno runs with and without hyperground.
> The reults showed the following:
> without Hyper Ground: 168.6 hp / 178.4 ft/lb tq
> with Hyper Ground: 176.6 hp/ 191.6 ft/lb tq
> In Japan, our Hyper Ground kit (sold as Hot Earth for JDM) showed a 10hp
> gain on an R32 GTR. This type of "earth tuning" emerged in Japan a few
> years ago and is widely accepted there as effective in improving electrical
> efficiency resulting in a power gain. Our kit is offered as OEM factory
> option equipment on the 350Z (JDM),the Lancer EVO 8 (both US market and
> JDM), as well as other Toyota, Subaru, Nissan, Isuzu and Mitsubishi
> vehicles . Now, in order for any equipment to be offered as an option from
> the factory, the amount of testing involved is lengthy and strenuous; as
> well as any power/efficiency gains, stress testing/durability testing etc
> must be passed before parts get approved for sale as OEM equipment. Hence,
> the construction quality of Sun's product should be noted.
> When all is said and done, the only way to truly prove that our product is
> useful and effective to the SE-R community is to actually put in on and
> dyno it. Through dyno testing you can also find the best grounding points
> for your application as well. We have not yet had the chance to directly
> test the Hyper Ground System on an SE-R; unfortunately, although we would
> like to have data on a vast array of makes and models, we are not in a
> position to be able to dyno every car available. Just as you noted, "the
> only way to know is to try and document it." If you come across any one who
> has actually dynoed an SE-R with Hyper Ground we would be very interested
> in seeing the results as well. Additionally, if I come across any more
> information specific to the SE-R regarding Hyper Ground, I will be more
> than happy to forward the info to you. Again, thanks for your inquiry; we
> look forward to hearing from you again soon and gaining the support of the
> SE-R community!
> SE-R community!
Originally posted by redmaxpa007
that was an ORGY members car..
Originally posted by Ceasars Chariot
anyone got engine pictures ?
there's definitely a pic of the ground points...
someone hosted the pic once for me...
if you can't find it, let me know and I'll forward
when I get a chance.
FLO_BOY
I cant comment on the hyper ground kit, but i worked on a civic that wouldn't start. I cleaned and reground all the grounds and positive cables under the hood and after it started right up. Thats like an increase of 40hp and 10 ftlb cause thats all civics got.
Originally posted by Max Noob
bump... ahha.. can someoen rehost the ground points pic on page 1 or 2.. i want to do all the spots on my 95. its probaly all dirty on those spots by now.
http://webpages.charter.net/tranau15.../diyground.jpg
thanks...for all 6 of those spots are there already stock grounds there, or did someone just make up those spots cause they work? so if i didnt know where to find these i can just open up my look and look for all 6 of the stock grounds and jsut renew the wire or add extra right? goign to walmart soon for all the wire.
you CAN just look for the spots, or ask if you can't figure it out.
FLO_BOY
