Headlight Question
Old Apr 12, 2003 | 08:56 AM
95GreekMaxSE's Avatar
Headlight Question
I was dribving at 3 am in the dark in the middle of know where and noticed that my headlight beams dont show up on the ground at all..it just illumnates streets lights and thing high up in the distance, but no lighting beam on the ground, should i re-adjust and lower the beams or is this normal??
Old Apr 12, 2003 | 09:24 AM
njmaxseltd's Avatar
You have Silver Stars, yes it's normal. They look good on your car but do a poor job lighting up the road in front of you. Put a set of Sylvania Xtravisions in or try the Sylvania Cool Blues for a whiter light. The Xtravisions are the best standard Halogen 9004 bulb out there. They clearly light up the road in front of you with a big wide beam, sometimes overpowering the car next to you.
Old Apr 12, 2003 | 10:09 AM
pruizgarcia's Avatar
The Wagner Bri-Lites are just as good also. You can't go wrong with either one. Make sure your lights are adjusted accordingly, this can also make a difference.
Some day we will have the aftermarket projectors for our 4th Gen Maximas.
Pedro
Old Apr 12, 2003 | 10:34 AM
ChristheNite
Question
Hey I have Sylvania SilverStars BUT the problem is I want the lights next to the head lights (not sure the name, i was thinking CORNER LAMP, but thats in the bumbers) to match, any Idea what i bulbs I can buy to make my lights match. Thanks!
Old Apr 12, 2003 | 04:13 PM
Re: Question
Someone recommended to me the PIAA X-Treme Whites since I have the 4000k BriLites. They match up real good when you rewire the corners; better then the Polargs and OEM's.
Pedro
Old Apr 12, 2003 | 04:34 PM
bb0ys's Avatar
Re: Question
Using whatever 1157 bulbs are in the corner lamp, do this if you want:
Remove the corner lamp housing.
Take the bulb out as if you were going to replace it.
Remove the top nub from the metal base (there are 2). It is the one higher up and closer to the bulb.
Cut a thin strip of electrical tape and wrap it around the metal base where the upper nub used to be.
Put the bulb into the housing you removed it from BACKWARDS. In otherwords, but the bulb in so that the remaining nub (the lower one) goes into the spot where the upper one was.
Turn your lights on and make sure the corner is brighter than the other corner.
Replace the fixture and repeat all except the last step for other side.
Old Apr 12, 2003 | 04:38 PM
mrmaxima97's Avatar
Re: Re: Question
Worked for me, although with the Xtravisions everyone thinks I have my high-beams on.
Old Apr 12, 2003 | 04:53 PM
bb0ys's Avatar
Same here
I have Xtravisions and more often than before I had them, I get people flashing at me to turn off my high-beams...except my lows are on! My lights are properly angled as well. Sorry, if you're one of those oncoming drivers
AaronL
Nov 15, 2020 11:52 AM
03VQMAX
Nov 10, 2015 03:39 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
sdotcarter
Sep 2, 2015 09:53 PM
