getting gas sprayed in your face hurts.... alot.
yes, yes it does. last time i change my fuel filter!
i forgot to de-presureize my fuel system, and i finaly got the fuel hose off my i had to stick my face in there so i could see how much further i had to pull on the tubing. so after i wigled my hands around my abs, i pulled with one final grunt, and all of a sudden gas shot out so quickly and sprayed me on my face, eyes, and shirt. i just stumbled back a few steps and rubbed my eyes in shock, and in pain. so i ran inside a flushed my eyes out with water. after the burning went away i went back out to my car. so as i went back, it banged with gas. then it hit me that i forgot to disconnect my battery! ahh! thats the last thing i needed to happen is my car to explode because of the fumes. well regaurdless, and to make along story short, i put it all back together and it works fine.... i think.
on a couple of days i stop and i can smell gas... but i am not sure if it is my imagination, or if there is something wrong.
i also changed my front 3 spark plugs. for some reason i could not get my back 3 out... almost like the wrench was too samll or big. so now i am also experiancing weird "blurps" if you will, when i am at a red light... and also it seems to hesitate when accelerating sometimes. i am gonna have to check everything over later when i get another day off. well thats my story.
Chris
i forgot to de-presureize my fuel system, and i finaly got the fuel hose off my i had to stick my face in there so i could see how much further i had to pull on the tubing. so after i wigled my hands around my abs, i pulled with one final grunt, and all of a sudden gas shot out so quickly and sprayed me on my face, eyes, and shirt. i just stumbled back a few steps and rubbed my eyes in shock, and in pain. so i ran inside a flushed my eyes out with water. after the burning went away i went back out to my car. so as i went back, it banged with gas. then it hit me that i forgot to disconnect my battery! ahh! thats the last thing i needed to happen is my car to explode because of the fumes. well regaurdless, and to make along story short, i put it all back together and it works fine.... i think.on a couple of days i stop and i can smell gas... but i am not sure if it is my imagination, or if there is something wrong.
Chris
Re: getting gas sprayed in your face hurts.... alot.
Chris
Chris
Sorry to hear about the gas incident...
let's just hope that one of the "WARNING: BEFORE YOU DO THIS" messages you pay attention to is the "don't work on your car raised only by a jack", or the warning messages for working with springs, because those could get uglier than a spray in the face.
Originally posted by ny96max
i just pulled the fuse out for my fuel pump and let the car run for about a min or two to get whatever gas was left out of the lines.
Ant
Ant
Re: Re: getting gas sprayed in your face hurts.... alot.
Originally posted by ljl10
Something tells me that if you change those back three plugs your hesitation issues will go away. How many miles did the old plugs have on them?
1.) plugs were nevr changed.
or
2.) car was taken to a dealership and was serviced.
or
3.) someone who had the car knew to put ngk's in.
my guess is either 1, or 2... probably and hopefully #2.
I kinda know how that feels! The first time I changed my oil I didnt know that oil came out of the filter when you took it out. I got under my car so I could get a good grip on it and turned it and hot oil came pouring down on my face. I got some in my mouth and all over my face, it wasnt fun.
I had a car battery pop in front of me..... I was about 3 or 4o feet away from it when it happened......... My Dad had a 74 Plymouth Duster, and the battery went out on it..... I helped him charge the battery, and when the batterey was charged, my dad went to start the car, and the top of the battery came off, and I got sprayed with a little bit of the battery acid..... I was extremely lucky that none of it got in my face or eyes.... That happened when I was about 12 years old....
Originally posted by BadKarma99-4spd
did you wash your engine bay out after you got gas everywhere? if not you probably are smelling it, gas is the kind of stuff that just dosent want to go away.
good luck
good luck
ef9
Oct 4, 2015 08:43 AM
