anyone with RVM UDP leaking seal?? or hitting the crank sensor???
#1ok guys i've had the RVM UDP for 2,500 miles on my car.i changed my crank sensor (REF) and i seen scrapes marking on the sensor looks like the timing ring is touching it. i tighen down the allen screw when i installed it. anyone ??? how do i fix it
#2i seen my crank seal leaking 2.i changed it (dealer part).(was not leaking before).went in good (seal). put some lube on the UDP where the seal and pulley meet. anyone have these problems??????? how do i fix it??
there is a thread in the group deal forum that talks about Definitive VQ pullies vs. RVM. They said what you are talking about was inevitable with the RVM pulley because of the way it is made.
Re: anyone with RVM UDP leaking seal?? or hitting the crank sensor???
I had the same problem a couple of months after I installed it. All I did was just rplace the seal and its been fine since.
Re: Re: anyone with RVM UDP leaking seal?? or hitting the crank sensor???
Re: Re: Re: anyone with RVM UDP leaking seal?? or hitting the crank sensor???
No. It started leaking and I couldn't find out what the hell it was until I got it checked out.I replaced the seal there after
Originally posted by Shoooter_j
Did you originally replace the seal when you installed it?
boomerbrian
Sep 2, 2015 03:46 PM
