Code 0111 Question.
Old Apr 21, 2003 | 08:57 PM
Rogo02SE's Avatar
Code 0111 Question.
I had the CE light come on and code 0111 was pulled from the ECU.
There was no issues with the car so I just reset the ECU but the CE came on after about 50 miles. Same thing code 0111 (EVAP purge flow monitor fault).
Any info on fixing this problem is greatly appreciated.
Old Apr 22, 2003 | 07:27 AM
96SE NUH?'s Avatar
Re: Code 0111 Question.
I pulled the same code. Hows your gas mileage??
Old Apr 22, 2003 | 03:00 PM
Rogo02SE's Avatar
about 22MPG, and yours??
Old Apr 22, 2003 | 05:49 PM
Swafford98's Avatar
MAybe this will be helpful to you guys.
I had the same code for a while and i replaced a few sensors trying to fix the problem but none of that worked. Come to find out, having a strut bar like i do. The bar was rubbing on a hose connecting to the EGR valve and made a hole in it. I replaced the hose and the problem is fixed and the light never came back on. Just check all of your hoses connecting to your egr valve and evap cannister.
Mine was like that for a while and eventually fouled out the cylinder 5 plug causing my car horrible.
Old Apr 24, 2003 | 12:07 PM
96SE NUH?'s Avatar
the same, the best was 24MPG but that was only once...
doctorpullit
Mar 29, 2016 11:08 AM
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
