URGENT: Windows not closing!
Old Apr 23, 2003 | 01:31 PM
henock
I went to install the back speakers i got today. I rolled all the windows down to let some cool air in the car while iwork.. but now when i try to roll them back up.. they dont work.. same thing with power door locks.. all fudged up.. there were no signs of the windows failing in the past.
the most i changed recently was disconnecting the rear brake light inthe back window to get to the speakers and reset the ecu yesterday.
i need help desperately bc i need the windows to be CLOSED before i get jacked!!! please help
Old Apr 23, 2003 | 01:35 PM
njmaxseltd's Avatar
Fuse pannel might be a good place to start looking.
Old Apr 23, 2003 | 02:11 PM
Eric L.'s Avatar
When installing the speakers, did you unplug the window switches?
Old Apr 23, 2003 | 02:14 PM
kushane's Avatar
This happened to me when I was installing the FRONT speakers. But seems like he was messing with the rears. Can't see how that would affect the switches , locks etc.
Old Apr 23, 2003 | 02:21 PM
xHypex's Avatar
I think you may need all 4 switches for things to function properly (but don't quote me on that). Did you overload a circuit and blow a fuse or something? I know the window switches/power locks fuse is in the engine bay to the right of the battery. It's a 30A fuse (green on my car) on the bottom right hand side.
-hype
Old Apr 23, 2003 | 02:28 PM
henock
never mind..
right after posting i went and dis/reconnected the battery.. all is fine now
thanks though
Old Apr 23, 2003 | 02:40 PM
iansw's Avatar
Originally posted by henock
never mind..
thanks though
Old Apr 23, 2003 | 02:48 PM
henock
Originally posted by iansw
Old Apr 24, 2003 | 09:52 AM
BluFlame's Avatar
This problem can also occur if your driver's window switch is going bad, none of the windows will roll up/down and you wont be able to lock/unlock.
Old Apr 24, 2003 | 11:04 AM
StygianMax's Avatar
never mind..
thanks though
Sounds like CTRL-ALT-DEL. Reminds me of this old 24-channel mixer I use where very occassionally, there's no signal on one single channel. Power down, power up & it's back.
Old Apr 25, 2003 | 05:22 PM
henock
ugh.. it happened again.. this time while i was getting seat covers installed.
*checks fuse panel*
Old Apr 25, 2003 | 05:47 PM
henock
fuse is fine. dis/reconnect dosent work anymore .. only driver's window works
Old Apr 25, 2003 | 05:52 PM
ghetto_bill's Avatar
happened to me before. i soon realized it was the button right above all the switches for the windows on the driver side. it was pushed down so i couldn't open or close any of the windows except the driver's one. try it; the solution might be the simplest. well in my caes atleast.
Fbana41
Aug 29, 2016 12:18 PM
Garrettz459
Sep 28, 2015 02:50 PM
lrb6805
Sep 24, 2015 05:03 PM
