Polishing valve cover
Old Apr 23, 2003 | 06:23 PM
waveridr85's Avatar
I am looking to polish my valve cover to get a nice shiny look. Thing is I am not completly sure on how to do this. What I think I will need to do is sand down the valve cover with a series of sand papers. After that i will use a polishing compound with either a cloth or some sort of buffing tool. Will I need to take the valve cover off to do this? If so will i need to replace any gaskets?
Old Apr 23, 2003 | 06:48 PM
nupe500's Avatar
Jedi Knight
Re: Polishing valve cover
To do the whole thing...you would have to remove it..but if you're just worried about the top and front area...I'm sure you could do that without removing it.
Old Apr 23, 2003 | 07:14 PM
plurco's Avatar
actually unless you have some scratches you only need to sand with maybe 200 and 800 grit. Then the best way to buff it is to use a die grinder with a buffer wheel.
Old Apr 23, 2003 | 07:17 PM
waveridr85's Avatar
if i take the whole thing off will i need to replace gaskets?
Old Apr 23, 2003 | 08:21 PM
nupe500's Avatar
Jedi Knight
best to do so!
Old Apr 23, 2003 | 08:39 PM
waveridr85's Avatar
so where do i go about getting a gasket for the front valve cover? how much are they?
Old Apr 23, 2003 | 09:28 PM
StygianMax's Avatar
Is a die grinder anything like a Dremel tool??
Old Apr 23, 2003 | 10:31 PM
Max240's Avatar
Once you have it done, be sure to post some pics of it. good luck with it.
Old Apr 24, 2003 | 11:04 AM
plurco's Avatar
sort of I suppose, except it will handle much larger atatchments, has more power and runs of compressed air.
Old Apr 24, 2003 | 11:15 AM
StygianMax's Avatar
Ahh...all I have is a Dremel tool and an orbital sander. The Dremel comes in handy with the small headed bits to polish the tight spots (& there are lots of those!). I need to do a lot more polishing before the upper plenum looks evenly shiny.
Old Apr 24, 2003 | 12:59 PM
araffio's Avatar
I removed my valve cover and sanded it with grits of 60, 80, 100, 200, 300, 600 wet,800 wet, 1000 wet, 1500 wet and then 2000 wet.
Then used some Mothers metal polish with a rag and several applications. Now it's like a mirror. Start to finish was about 12 hours total.
Working on my intake manifold now which is a LOT harder, but doable.
ny96max is the king of polishing and also who I got all my info from before getting started.
Old Apr 24, 2003 | 01:01 PM
waveridr85's Avatar
just did it, doesnt come out chrome looking but it is much shinier, will try to get pics up soon, i used a dremel with various sanding / gringing bits, and polishing compound, came out niuce
Old Apr 24, 2003 | 01:10 PM
StygianMax's Avatar
Two Qs:
- Did you polish by hand or sander (or both)?
- Does "wet" sandpaper just mean that you need to rinse it with water now & then to get rid of the grit?
Old Apr 24, 2003 | 01:15 PM
araffio's Avatar
Two Qs:
- I did it all by hand
- Wet sandpaper is just that, sandpaper used when wet. Go to any auto parts store and they will have it, it's black, not brown. I got it at Pep Boys. Regular sandpaper will not work when wet, it will get soft and fall apart. Get sandpaper made for wet sanding, spray the valve cover with water, and get sanding.
Old Apr 24, 2003 | 01:18 PM
StygianMax's Avatar
- Wet sandpaper just that, used when wet. Go to any auto parts store and they will have it, it's black, not brown. I got it at Pep Boys. Regular sandpaper will not work when wet, it will get soft and fall apart. Get sandpaper made for wet sanding, spray the valve cover with water, and get sanding.
Thx.
Old Apr 24, 2003 | 01:22 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
Could you post pics? I was checkig out your cardomain site and wanted to know what kind of grill you had in the lower valence.
Old Apr 24, 2003 | 01:23 PM
araffio's Avatar
No pics yet. Once the weather is nice, I'm taking a ton of new pics for my site. Those pics are very old and outdated, my Max is a lot different now.
That's a Trenz valence. I sold it a couple months ago
Old Apr 24, 2003 | 01:30 PM
I like it
Old Apr 26, 2003 | 10:57 AM
waveridr85's Avatar
check my homepage for pics, all i used was a dremel, input appreciated
Old Apr 26, 2003 | 11:00 AM
araffio's Avatar
Looks clean, but not nearly as smooth or shiney as it gets with hours of sandpaper and polish.
It comes out to a mirror finish...
That looks alright
TKHanson
Nov 24, 2018 01:39 AM
jonreidhead
Jan 6, 2016 09:38 AM
tseng1023
Oct 15, 2015 08:30 AM
JonBlz
Oct 5, 2015 06:02 PM
hayne
Oct 5, 2015 11:53 AM
