VI Installed. Working BACKWARDS! HELP!
Old Apr 24, 2003 | 03:48 PM
ZuMBLe's Avatar
I have my VI installed but its working backwards. There is vaccum to the actuator before the RPM switch goes off. When the RPM goes off, the actuator gets no vaccum. =( Whats wrong!?
Old Apr 24, 2003 | 04:04 PM
Confused's Avatar
Permanent Maxima.org Resident
sounds like you have the solenoid vacuum backwards.
Vac Line one
vac source - check valve - canister in
Vac Line two
canister out - switched port of solenoid
Vac Line three
switch out to actuator
Sounds like you switched the solenoid ports (2 & 3)
you might also want to indicate which solonoid and cannister you are using and what exactly you are seeing (position of actuator)
Old Apr 24, 2003 | 04:18 PM
ZuMBLe's Avatar
I think the vaccum switch is broken. No matter how I reverse the tubes, there is vaccum going straight through. This is the GM switch.
Old Apr 24, 2003 | 04:34 PM
ZuMBLe's Avatar
Bah, after some testing. I think the GM switches require a relay. Power must be given to keep the VI off, then power must be cut to turn the VI on. I think. This sucks.
Old Apr 24, 2003 | 04:59 PM
Nealoc187's Avatar
SLOW
You've wired it wrong. The switched ground from the harlan is not corrected to the right wire. There's nothing wrong with your vacuum switch if the VI is actuation, you've just hooked it up backwards.
Old Apr 24, 2003 | 06:35 PM
ZuMBLe's Avatar
Here is the thing. When I unplug all the wires from the switch... vaccum still goes through.
Old Apr 24, 2003 | 07:55 PM
plurco's Avatar
I have a GM switch.
What is happening is that you have one of the vaccum lines hooked up to the vent. This way when the switch is non activated, the vaccum is passing through the vent and out to the VI. causing the vaccum inlet to act as a vent when the switch is activated.
Old Apr 24, 2003 | 08:04 PM
ZuMBLe's Avatar
But, there are only two possible holes. One is covered by foam. That is the vent. I don't have anything plugged in there. The silver nipple goes to the vaccum source. And the non covered nipple next to the foam one is connected to the actuator. I'm not the only one with this problem. A-Ron max has the same problem. We got our VIs installed by two different people.
Originally posted by plurco
I have a GM switch.
Old Apr 24, 2003 | 08:14 PM
plurco's Avatar
well you will not be able to make this work properly with a relay. It "will" work but olny for a finite amount of time. You see the switch will spend 99% of it's time energized, and avter a little while you will burn out the coil in the solenoid.
Old Apr 24, 2003 | 08:18 PM
ZuMBLe's Avatar
Bah, so I'm going to say the problem is the switch. Where can I get another type?
Old Apr 24, 2003 | 08:19 PM
Requin6's Avatar
no no...remove the foam...the silver is the vent. the one with the foam and bracket receives the hose from the canister and then the other black fitting goes to the actuator.
EDIT -- included picture of GM with silver venting.
--Paul
plurco's Avatar
here is what my GM switch looks like. It is off a '87 S-10
http://images.cardomain.com/member_i...9/287228_6.jpg
Can you not use the opening with foam in it? the foam should not effect anything, unless you can not get a hose on it.
Old Apr 24, 2003 | 08:24 PM
ZuMBLe's Avatar
My switch looks a little different.
http://www.joemutt.com/zumble/VI/VI_install_kit.jpg
Old Apr 24, 2003 | 08:42 PM
Requin6's Avatar
i have used this switch on mine and another i just installed over the weekend...it works. just remove the foam.
--Paul
Old Apr 24, 2003 | 08:47 PM
ZuMBLe's Avatar
You're supposed to remove the foam? Plug something in to the foam port? Please give details. The car is still sitting in the garage ready to be worked on. "Delco Remy" switch?
--Paul
Old Apr 24, 2003 | 09:01 PM
Requin6's Avatar
yes remove the foam...the hoses go as follows...
-vacuum source to check valve to canister (check valve on napa can is the larger of the two).
-canister to inlet with foam removed.
-other black inlet (common port) to actuator.
the silver inlet is the vent to open air.
--Paul
Old Apr 24, 2003 | 09:14 PM
ZuMBLe's Avatar
It worked!! Thank you!!! John's illustration on his site was very misleading!! WOOO!!!! Thank you! =)
--Paul
Old Apr 24, 2003 | 09:27 PM
Requin6's Avatar
you're welcome, glad to hear you got it working.
--Paul
Old Apr 25, 2003 | 05:50 AM
Confused's Avatar
congrats!
Old Apr 25, 2003 | 07:29 AM
ZuMBLe's Avatar
I still haven't driven it yet with the VI functional. I will tonight though. My RPM switch is mounted in the engine bay so I hope I don't have any RPM switch problems.
Originally posted by Confused
congrats!
Old Apr 25, 2003 | 01:25 PM
plurco's Avatar
I just hope I get my harlen switch soon. It's been 1 month now.
Old Apr 25, 2003 | 01:30 PM
ZuMBLe's Avatar
You don't have a RPM switch? Hey, you can always get a MSD window switch. Just set the upper window to like 8000 rpm or something.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
Hailstatejig
Sep 2, 2015 06:52 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
