UPDATE on my 95 SE's MPG situation
Old Apr 24, 2003 | 08:51 PM
D1NOnly34's Avatar
Well, I took the advice of what you guys said. I filled up my tank (just about) this past Easter Sunday..came out to be 15 gallons..today I have about a quarter tank left...and Ive traveled 185 miles. This is HORRIBLE. Makes me sick to my stomach! Am I looking at an injector problem? I need any help you guys can give me, I cant afford to be traveling only 200+ miles on a full tank. This was a big part of the reason why I sold my 1986 GT 5.0 V8 Mustang.
Old Apr 24, 2003 | 08:57 PM
nismos14's Avatar
§è~® f®ÈÄk
uhh what advice did u take?
Old Apr 24, 2003 | 09:04 PM
D1NOnly34's Avatar
At first I tested my MPG with only 5 gallons of gas. They told me it was better to test on a full tank. 5 gallons would have given me non accurate answers.
Old Apr 24, 2003 | 09:06 PM
nismos14's Avatar
§è~® f®ÈÄk
ooh ok.... well did u check ur tire pressure? also where does ur car usualy shift.... i.e. how hard are u gassing everytime u accellerate?
Old Apr 24, 2003 | 09:13 PM
D1NOnly34's Avatar
I havent checked tire pressure, I have low profile tires for my 18's. Ill go and check that in the morning. Also, I dont really gun it a lot. Usually shifrt around 3000 RPM, sometimes even less. I dont liek to accelerate a lot because since my car isnt responding liek it should, it shifts harder, feels like its holding back actually.
Old Apr 24, 2003 | 09:30 PM
bill4max's Avatar
First start with the basic tune up like new plugs ,fuel filter, oil even change your trans oil if its old. Put some good fuel injecter cleaner in the tank too. Also it could be your knock sensor as it is known for poor gas milage. Check the codes in the ecu 0304 also you can test it with an ohmeter.
Old Apr 24, 2003 | 09:31 PM
svarog's Avatar
Come on now -- figure out what your actual MPG is first
No offense, but your numbers are totally meaningless unless you do a real test of gas mileage.
1. Fill your tank ALL THE WAY UP using premium gas. Not, ALMOST full, but ALL THE WAY UP. Reset your trip odometer.
2. Drive for as long as you want, but use up at least 1/2 tank.
3. Go back to the same gas station and fill up using premium gas again. (This is because different gas pumps may have different shutoff points).
4. See how many gallons you took, and divide that number into the number on your trip odomter. USE A CALCULATOR.
5. Write down the number. This is your MPG. Come back here with that number. For example "16.5" or "18.6" or "20.1". Not "186 on most of a tank" or whatever.
Old Apr 24, 2003 | 09:37 PM
D1NOnly34's Avatar
Sorry forgot to mention:
All of these were changed recently
*oil
*spark plugs (NGK plats)
*knock sensor
*fuel filter
*air filter (somewhat)
*put in Fuel system cleaner about 2 weeks ago
Im just posting on what Ive seen so far, I can understand what you guys are saying about it being meaningless, just wanted to post on my situation as of yet, regardless fo whathappens, the MPG still seems horrible to me, something is wrong.
Old Apr 24, 2003 | 10:01 PM
svarog's Avatar
I mean you actually need to fill it up full -- to where the pump shuts off, anyway -- and test from there... "almost full" could mean anything. Remember that the gas gauge is not 100% accurate on the Maxima, or any other car. Like most vehicles, it stays up at the "FULL" area for a long time, and then falls more quickly past the 1/2 tank level.
So when you fill it up to "almost full", the gas gauge might show near full -- but you might have only 14-15 gallons in your 18.5 gallon tank. Then you get to "almost empty" and you actually still have 4-5 gallons left. In this case, you think you used nearly a whole tank, but you actually only burned 10 gallons -- which on 185 miles is giving you 18.5 MPG, which is not that unusual.
Do you see what I mean?
Old Apr 25, 2003 | 05:43 AM
njmaxseltd's Avatar
Houston, we've found the problem!
HEAVY 18" WHEELS! They will suck your tank dry, especially if you do a lot of city driving.
Throw your stock wheels back on for a tank and see what MPG you get.
Old Apr 25, 2003 | 06:40 AM
D1NOnly34's Avatar
I understand completely, thanks for the explanation.
Hmmm I didnt think my 18's could be THAT huge of a problem, yes I do a lot of city driving, basically the longest distances I go on a regular basis is to School, 10 miles to get there, 10 miles to get back. Everything else is close by.
Old Apr 25, 2003 | 08:07 AM
nismos14's Avatar
§è~® f®ÈÄk
well try it and see thats the only way to find out for sure
Old Apr 25, 2003 | 11:33 AM
Eric L.'s Avatar
IF you do city driving, don't be surprised to average 16-17mpg, especially if you use your A/C.
Old Apr 25, 2003 | 05:43 PM
maximomo's Avatar
OK, somebody correct me on this if I'm wrong but...
Isn't the odometer calibrated on 15" wheels?
When you put 18" wheels on doesn't this effectively reduce the number of miles you rack up on the odometer by about 15-20%?????
So, if you throw the stock rims back on you'll get what looks like better mileage. Then it will suck again when you put the 18" rims back on.
The first thing I would do is check to see if your ECU has stored any codes. You code have a faulty cam position sensor and your check engine light would not light. Could be anything else. And you will stillhave to do all of the fundamental sensor tests even after you swap your rims off and back again.....
Old Apr 25, 2003 | 07:50 PM
D1NOnly34's Avatar
My ecu is throwing NO CODES, just 05 05..which is no error detected. I didnt know 18's made that much of a difference, now I do though, and I live in Miami, very hot, just got A/C fixed so I use it a lot, if not all the time. Oh well
Old Apr 25, 2003 | 08:59 PM
Bgohan's Avatar
Is your speedo off from changing tires size from stock?
aw11power
Oct 10, 2021 04:57 AM
mkaresh
Mar 12, 2018 06:48 PM
ef9
Oct 4, 2015 08:43 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
homewrecker
Sep 24, 2015 07:01 PM
