Check Engine light and Ignition switch
Old Apr 27, 2003 | 09:13 PM
sandman1098's Avatar
Is the Check Engine ligh supposed to come on when you turn on the ignition (just before you crank the car)? Mine does not, but I know the bulb is working though...... Could that mean that something is wrong with my ECU?
Old Apr 27, 2003 | 09:42 PM
Miasma's Avatar
uhh... if nothing is moving in the engine, all systems are not go, and only when all systems are in working order will the CEL go off. Thats like saying, my oil pressure light is on before i start the car and there is any oil pressure! whats wrong?!
Old Apr 28, 2003 | 05:45 AM
njmaxseltd's Avatar
Re: Check Engine light and Ignition switch
How do you know that the bulb is OK if the light never comes on? And yes, it's supposed to come on when the key is in the on position just before you start your car.
Old Apr 28, 2003 | 05:56 AM
The light comes on sometimes after I crank the engine..... I also took the instrument cluster apart to check the bulb.....
Is this any indication of a bad ECU?
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
