Grounding kit
Old Apr 28, 2003 | 12:03 PM
Kehops's Avatar
Grounding kit
Might be a little OT but I was browsing through 4sale and GD sections and couldn't find any grounding kit info.
I've heard good things about this "mod" and would like to purchase a set if the price is right.
Old Apr 28, 2003 | 12:40 PM
MacGyver265's Avatar
Re: Grounding kit
All you have to do is get some battery cables, bolts, and sandpaper. Drill a hole somewhere in the sheetmetal connected to the frame, sandpaper the area, then connect the battery cable to the negative terminal of the battery to the hold you just drilled with a bolt.
Viola! Hyper-ground!
You can also make the grounds to the headlights bigger as well.
I think the best thing you can do in conjunction with this is to add a 0.5 Farad or 1 Farad capacitor to the battery in parallel. That should get rid of a lot of dimming problems.
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
