where is the engine harness?
Old May 2, 2003 | 08:28 AM
kenju4u's Avatar
Hey guys where is the engine harness located? I needed to check to see if its cracked or damaged.
Old May 2, 2003 | 12:12 PM
hlh0501's Avatar
it is the big black bundle of wires coming from the passenger side of the firewall area, then splits out into all the different harnesses for everything under the hood.. here i highlighted the harness in these two pics, plugged on the motor, and not.
Old May 2, 2003 | 12:16 PM
kenju4u's Avatar
thanks man! appriciate it!
Old May 2, 2003 | 12:18 PM
hlh0501's Avatar
no prob, maybe not the easiest thing to check for problems, but most likely areas if you do have a split is probably that lower left corner where it turns (lookin at the pic) .. but that is all in loom, etc
good luck
Old May 2, 2003 | 01:16 PM
kenju4u's Avatar
you wouldnt happen to know which wire is going to the vehicle speed sensor would you? I am getting a Vehicle speed sensor and signal from A/T to ECU error. I changed the speed sensor a few days ago and everything was running great until i got the light again today. The TCU test came back with speed sensor circuit shorted or disconnected. I know if i reset the ECU right now it will work fine for a few days and then probably come back again...i guess there is a short some where but not sure which wire.
derekinthez
Nov 13, 2022 04:00 PM
knight_yyz
Oct 24, 2015 08:05 AM
