New pads but noisy, why?
Old May 2, 2003 | 01:51 PM
03G35's Avatar
I changed my rear and front brake pads like 3 weeks ago, when I first put them on it was working fine no noise or anything, but now everytime I step on the brakes it makes that squealing noise?Can someone please tell me why this happens? Did I have to change the rotors too or something?, my front pads are midas lifetime warranty and back once are some other brand I can't remember the name, but they are all premium.
Old May 2, 2003 | 02:01 PM
Tim 95 GLE's Avatar
Metallic pads squeal, did you turn your rotors? If not, that could be it also.
-Tim
Old May 2, 2003 | 02:14 PM
Kashoggio's Avatar
use oem
Old May 2, 2003 | 02:23 PM
heems27's Avatar
You are probably using metallic pads. Maximas need ceramic pads. Metallic pads give off loads of dust and are LOUD!
Old May 2, 2003 | 02:27 PM
03G35's Avatar
I'm guessing the Midas brake pads are metallic, all that black stuff from the brake pads are sticking into the rotor and now I can see all those black spots on the front rotors
I did turn the rotors , I had some grease on them so I kept turning and turning to clean them
Old May 2, 2003 | 02:33 PM
03G35's Avatar
LOUD? The loud sound is coming from the back but they are not metallic pads , the metallic are at front
the sound I hear is when the car is been on the parking for a little longer time and after I start it up and put it in reverse and step on the brakes, it makes this loud sound coming from the back, like vibration and loud sound my head just wants to explode that how loud it is.This is another problem if anyone can please explain this, Thanks
Old May 2, 2003 | 02:44 PM
hacim105's Avatar
Here's the problem with that. The back brakes don't engage unless your e-brake is on, because that is what they are for. If it isn't coming from up front then either your e-brake is sticking or you're not hearing things corretly.
Old May 2, 2003 | 04:33 PM
njmaxseltd's Avatar
Not true!
I run Axxis Metal Masters which give almost no dust. They also stop very smooth and are quiet.
Buy a new shim kit from Nisssan and install it. Use the lube and anti squeal grease that comes in the kit. Your brakes will be nice and quiet again.
Old May 2, 2003 | 06:08 PM
Dev's Avatar
Dev
rear pads engage when you press the brakes as well....obviously
its not ONLY for the e-brake
Originally posted by njmaxseltd
Not true!
i have metal masters front and back and they dont squeel, and have very minimal brake dust.
make sure you use the anti-squeel goop.
Old May 2, 2003 | 06:21 PM
nadir_s's Avatar
vicodin ... gift of life
ok well i have two things you might want to consider:
SHIMS
ANTI-SQUEEL GLUE
if those two aren't present, then most likely it will squeel. When I got my pads changed, they put shims on the front pads but didn't use any glue. It squeeled so bad. And for the rear... they didn't put shims at all!
Old May 2, 2003 | 08:11 PM
s0ber's Avatar
someone give the noob some knowledge real quick and tell me what are shims? :P
Old May 3, 2003 | 06:16 PM
max4evr's Avatar
Re: what are shims
Shims are the thin sheetmetal clips that slip over the backside of the brakepads, fitting between the pads and the caliper.
I've had a terrible squealing with my new front pads, even after using the anti-squeal goop. Guess I'll buy new shims and see if that helps.
Old May 3, 2003 | 06:26 PM
lefty
Turning means machiening the rotors...hope you are not referring by your post that you actually physically "Turned" the rotors to clean them"
Old May 3, 2003 | 07:24 PM
SleepyMaxxx68's Avatar
Yeah turn your rotors <-- (spelling?) My back brakes made this insanely loud noise for a couple of days liek really bad scraping....just turn you rotors no prob....the sound should be gone. Plus it helps for brake wear....DON'T BE A SCHOOL BUS!
Old May 4, 2003 | 03:08 PM
Yeti's Avatar
My 1998 Maxima started having similar problems to what 03G35 described. When I am backing up, I get this loud horrendous "dragging" noise when I brake. It only happens in reverse and only when I brake. The noise is not a squeal as much as a "dragging" sound.
Has anybody ever seen this or know what might cause this?
Old May 5, 2003 | 07:31 PM
Yeti's Avatar
ttt
Old May 5, 2003 | 07:59 PM
03G35's Avatar
thanks all
when I was changing my pads , I did put the shims and cleaned them also sprayed the pads after I put the shims on with the glue, called "brake quiet" but just yesterday I went to the dealership and they said I need to replace my front rotors because they are to thin, so that might be why its making noise,
as for the back when going in reverse making that loud vibrating noise, I will turn my rotors somethimes this week to see if it will go away,
thanks again
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
05RLS2
Sep 27, 2015 09:24 PM
bbsitum
Sep 11, 2015 04:55 PM
