wiring harness woes
Old May 3, 2003 | 01:28 PM
Che's Avatar
Che
wiring harness woes
I installed my APC 9004 wiring harness kit last night and now my high beams don't work. I installed them according to directions on maximadriver.com. also, my high beam indicator in my dash is slightly illuminated. anyone know what the problem may be????
Old May 3, 2003 | 01:52 PM
patel_anu's Avatar
Re: wiring harness woes
it might be the wiring, double check to see if all the wires are correct, i'm thinkin its this cause i ran into the same problem with a regular harness i bought from autozone, i matched up the same colors and everything and the high beams didn't work, but than i switched the wires around and worked fine after that
if its not that than it could be the light bulbs itself, might be defective, hope that helps
Old May 3, 2003 | 02:13 PM
Che's Avatar
Che
is the wiring harness you have the one with the harnesses and relays?
because I did a search and found posts about the sw auto works harness
which is not the same one I have. I have the APC. I only have 3 wires on each harness, which ones should I switch?
Old May 3, 2003 | 03:21 PM
Che's Avatar
Che
anyone??
Old May 3, 2003 | 04:10 PM
patel_anu's Avatar
anyone??
nope, i bought just a regular harness with no relays or anything, i don't know which colors you need to change, i just changed mine around, i don't think thats safe but i went ahead and tried and i guess i got lucky
Old May 7, 2003 | 06:45 PM
maximaseefu's Avatar
still have the same problem, solutions?
doctorpullit
Mar 29, 2016 11:08 AM
Max Nu-BE
Sep 28, 2015 10:25 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
