Weird noises comin from my car
Old May 4, 2003 | 09:23 AM
nismos14's Avatar
§è~® f®ÈÄk
Sometimes when coming to a stop or when idling at a stop in gear, out of gear, clutch in clutch out...no matter what scenario.. i get this weird buzzing sound... its not always but it does happen and has been occuring more lately ... wtf is that????????
Old May 4, 2003 | 02:30 PM
nismos14's Avatar
§è~® f®ÈÄk
n e one?
Old May 4, 2003 | 05:38 PM
joaquink's Avatar
¿Hablas Español?
Where is the sound coming from? Is it engine speed dependent? Do you hear it with all of your accessories off? 'buzzing sound' is too nondescript to be able to help you out here. Maybe it's just a loose trim piece.
Old May 4, 2003 | 05:53 PM
nismos14's Avatar
§è~® f®ÈÄk
yah all accessories off, its like a droning sound, its very weird sounds like its coming from the engine bay somewhere, it didnt happen today at all tho...
Old May 4, 2003 | 06:13 PM
joaquink's Avatar
¿Hablas Español?
When it does happen, can you change the pitch or volume of the sound by revving the engine?
Old May 4, 2003 | 06:45 PM
nismos14's Avatar
§è~® f®ÈÄk
nope the pitch does not change at all, one time out of the 5 or so times its happened i revved and the sound went away, but all the other times it stayed but just for that one point where i came to the stop, and then it went away after i was going again and it wouldnt happen again at the next stop
Old May 5, 2003 | 02:48 PM
nismos14's Avatar
§è~® f®ÈÄk
seems like when i am at a stop and give it gas it goes away, if i give it gas once and it doesnt go away, i give it gas again, and it goes away.. and i can feel the vibration in the brake pedal when i am already stopped, and today i heard/felt the vibration while i was driving in 4th gear ..... my poor max
Old May 5, 2003 | 03:07 PM
joaquink's Avatar
¿Hablas Español?
Fear not, I have good news...
You can save up to 15% on your auto insurance with Geico.
Old May 5, 2003 | 03:12 PM
joaquink's Avatar
¿Hablas Español?
Actually...this is odd but perhaps you have a slightly different flavor of the exhuast noise that I had. It drove me nuts until I got it to fail in my driveway. Just for grins, try it out.
Set the e-brake firmly and then gently ease out the clutch in 1st and 2nd and feather the gas to see if you can make the noise while stationary. I also had to hit reverse a few times but finally got it. If this works, you'll have a much much much easier time isolating the sound. If it doesn't, try it without the ebrake, in a parking lot or something where you can repeatedly start and stop with someone outside the car listening. I had to lay down next to a speed bump while my buddy drove his truck back and forth over it so we could find where the suspension problem was.
Cheers,
JK
Old May 5, 2003 | 03:41 PM
nismos14's Avatar
§è~® f®ÈÄk
when i hit the gas the sound will normally go away... so if i feather the gas and let out in 1st 2nd or reverse it is going to go away ... but i'll give it a shot, i appreciate the help joaquink it also seems that the sound comes as something spins, it gets loud then quiet then loud then quiet.... i can't pin point it at all
Old Jun 3, 2013 | 08:38 AM
unreal2k1's Avatar
Weird Noise
Hi Guys,
I have been using the forum as a guest for years to find almost everything about my maxima here. So under the weird noise stickys and cannot find what the noise that I am hearing is. So when the car is started or at a stop I hear this weird groaning noise from inside the car almost like a pulsing sorta louder then lower noise. Like someone is slowly killing a robot lol. I am not sure what it could be as the car is functioning just great. Brakes are fine and the sound does not seem to be noticeable at all when driving only when first started or at a stop. Would the master boot cylinder make this noise? I have a 96 GLE and I love my car even tho its 17 years old and looks and runs great. Any help will be highly appreciated.
Old Jun 3, 2013 | 10:14 AM
bullet187's Avatar
It could be the radiator fan, mine started to make a buzzing noise whenever I had the AC on or if I was stoped a light. I changed it last week and haven't heard a noise since.
Old Jun 3, 2013 | 12:33 PM
DBear's Avatar
Just in case a 10 year bump is a record, I want to be part of it...
Unreal, I think what you're describing gets referred to a "droning" noise. I get that too at times. To me, that's entirely different from a buzzing, which is a higher sound, like what I get from my front dashboard. (I think the defroster vent causes it.) The droning is much lower in pitch. It sounds like it's coming from the front left side of the car, but I can only hear it from the driver's seat. I can't hear it if I'm standing beside the car.
There are some threads about that here, but I don't think anyone has solved it yet.
Old Jun 3, 2013 | 12:39 PM
asand1's Avatar
Fuel Pressure regulator, no joke.
Read here.
http://forums.maxima.org/4th-generat...tion-idle.html
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Jun 16, 2019 01:35 AM
maxinout93
Oct 27, 2015 01:29 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Jcof88
Aug 3, 2015 10:43 PM
