can this fit on stock 95 sawblades?
May 4, 2003 | 03:28 PM
I'm looking for some cheap rims(I got steel wheels and hubs)and I wanted to know if 225/60R15 tires would fit on 95 SE sawblades? Thanks.
May 4, 2003 | 03:35 PM
One more thing..........
I was told that a 3rd GEN wheel would fit in the spare tire area in my trunk.(I have a donut there now) What size tire would I need to make it fit? Again, thanks.
May 4, 2003 | 04:38 PM
Re: can this fit on stock 95 sawblades?
Quote:
If you want 225's and you want to keep the same diameter you need this size 225-55-15.
May 4, 2003 | 10:12 PM
Re: Re: can this fit on stock 95 sawblades?
Quote:
The same diameter as what? I have the 225/60R15 tires on my car now. I was thinking of a budget upgrade from my steelies and hubs and was going to reuse the tires.
May 4, 2003 | 10:51 PM
Re: One more thing..........
I replaced my Donut with a stock sawblade 15" wheel and stock tire in the spare tire location.
Then I went to the local fabric store and bought some 2 inch foam and cut it to line the entire trunk area under the trunk mat Three pieces cut to fit so it is not fastened down at all so if I want to ever change to something else later. This raised the mat enough that the stock spare tire cover (the masonite type piece) under the mat still fits and then the stock trunk mat goes on top as normal (so if reduces trunk space by 2 inches in height).
Works good.
White96MaxSE
