I Need Serious Help With My Maxima Shifter Fast
Old May 10, 2003 | 11:53 AM
ManualMaxima's Avatar
5th Gen till she dies!
I was driving down the road. I was stopping at a stoplight and i put the car into first, and then my shifter just went limp. It was not connected to anything. It was just stuck in neutral. I could move it around in circles, and it was just not working. What can this be. My car is on the side of the road, and nothing i can do. What could have cuased his, what can fix this.
I just had a clutch replaced about 2 weeks ago, can that be a cause. Maybe they messed something up! Help fast!
Old May 10, 2003 | 12:34 PM
1FSTMAX's Avatar
What have you tried as far as trouble shooting the problem? Have you tried checking the shifht linkage?
Old May 10, 2003 | 01:05 PM
i have not tried anything. Like it just happened and it is on the road. I am only 17 so my dad will have to check that out. I dunno what i am doing alot. My brother did not have time cause he had to go back to work form picking me up. He said that probely was what it is. How much does that usually cost to get fixed.
Old May 10, 2003 | 01:44 PM
1FSTMAX's Avatar
So the shifter will only move in circles? Can you shift into fist gear or any other gear with out the clutch?
Old May 10, 2003 | 03:08 PM
sleepermaxima's Avatar
ManualMaxima,
Here is my opinion/guess:
Your mechanic forgot to properly fasten the stick to the horizontal linkage. This joint resides above the catalytic converter. You will not be able to do much about it while it is on the side of the road. The shop that did the work will have to tow it in ON THIER DIME to fix the problem.
This is an easy fix if in fact this is the cuase of the problem. You should not have to worry about any damage to your car due to this problem either.
Later,
D
Old May 10, 2003 | 08:32 PM
hey man, that is what it was. I got a tow truck to tow it to a place and i got up under there with my manual and figured it out. The link beam or whatever ou calling was hanging like to hell. But yea that si what it was. I have not talked to the shop since they were closed. Thank you very much with your information
MAXSE5SPD
Aug 23, 2015 12:06 PM
wingsfan24
Aug 15, 2015 07:35 PM
Trin1j23
Aug 12, 2015 08:31 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
