Valvebody upgrade prob
Old May 10, 2003 | 02:52 PM
97blackv1's Avatar
i got the vb installed,just to make sure i could shift(carefully),
i got in the car and did the usual P-R-N-D-2-1
when i get to 1 it doesn't want to stay.
what did i miss?
Thanks i really need help here:>)
Old May 10, 2003 | 04:28 PM
97blackv1's Avatar
Anyone?Please_shift_me in the right direction
Old May 10, 2003 | 05:18 PM
BadKarma99-4spd's Avatar
where did you get if from, call them and ask for help. mine is sitting in my garage waiting for me to return to nashville.
good luck
Old May 10, 2003 | 06:12 PM
97blackv1's Avatar
got it from maximum tuning,i'll call him monday...thanks any automatic guru's out there?
Old May 10, 2003 | 11:40 PM
araffio's Avatar
What do you mean it doesn't want to stay?
Also, did you add enough fluid?
Old May 11, 2003 | 02:00 AM
97blackv1's Avatar
this was a dry run without the car started i am just clicking through before i put the pan on and the fluid in.
I'm wondering if a pin is set wrong.
Old May 11, 2003 | 08:34 AM
araffio's Avatar
The groove in the pin should be facing the rear of the car. That's the only pin to worry about
Old May 11, 2003 | 11:28 AM
97blackv1's Avatar
thank you:>)
I'll check it out and get back
Old May 11, 2003 | 02:58 PM
97blackv1's Avatar
fileld it up with fluid and gave it a few minutes and she won't go into gear!
Leave it to me(F@#k)
Old May 11, 2003 | 04:34 PM
Ninos_Maxima's Avatar
be the change u want2C
Did you get a Tranny cooler, Which brand did you use, I wanan do the same with mines.
Were do you buy a VB Mod from anyways??
Old May 11, 2003 | 06:10 PM
araffio's Avatar
Did you get the spring on top of the VB lined up? Did you face the groove on the linkage pin towards the rear of the car?
Unless you missed one of these, everything should be fine.
Sorry it's not working. I know what a bi_tch it is to get that VB out.
Old May 12, 2003 | 05:36 AM
97blackv1's Avatar
o.k.--
after taking the pan off again,it was the pin,it wasn't lined up with the
shift linkage!
will finish it off tonight or tomorrow night.....the cooler is installed got it from advanced auto(equivilent to hayden 404)about $39.00
Old May 12, 2003 | 06:32 AM
Dreizehn's Avatar
I'm a bit late but this was the problem right?
I have a write up on my homepage if anyone else needs it...
http://www.cardomain.com/member_page...=203031&page=5
Fbana41
Aug 29, 2016 12:18 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Dasmith
Sep 23, 2015 08:28 PM
