Ground Control Question, Need Answer ASAP.
Old May 11, 2003 | 09:43 AM
MaxEffect414's Avatar
Is there any fitment problems or issues with these that i should watch out for??
I'm using KYB-AGX and i was thinking about getting ground Controls, So what else should i know about these before i buy??
Trance
Old May 11, 2003 | 09:56 AM
krzymax's Avatar
Maxima owner since 2000
you will need to file down the round metal piece of the AGX so it will fit into the ground controls.
Old May 11, 2003 | 10:04 AM
The top or bottom of the struts and is the work hard to do yourself?
Also once this is done, is this the only modification i have to do for the front and rear???
Also how's the ride and quality??
Thanks for replying ASAP.
Trance
Old May 11, 2003 | 12:01 PM
BUMP! Anybody???
Old May 11, 2003 | 12:32 PM
chris j vurnis's Avatar
Ride quality is generally fair to poor with the ground controls.
Going from an SE spring at 250LB/IN, the ground control springs will be at least 100LB/IN tighter. Bare minimum increase in bump impact force will be about 40%-50%.
If you don't have dust boots, you need to be vigilant about keeping the threaded perch free of dirt and other debris. Makes it hard to rotate the perch to change the ride height when there is all sorts of junk in the threads.
Make sure you set the perch so that the locking bolt faces outwards. It makes it that much easier to access it when you need to change the height. No need to torque the locking bolt on the perch very tight.
Old May 11, 2003 | 03:37 PM
Thanks alot, Forget it i'm not going with those, I will stick with my H&R's, Thanks alot for the help.
Going to order them now.
Trance
Old May 11, 2003 | 06:06 PM
Nismo98's Avatar
How much is the drop in the sig picture.
Andrei
Matt93SE
May 24, 2019 02:58 PM
95Maxi
35
Sep 2, 2015 10:37 AM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
