MEVI Parts list - is it complete?
Old May 11, 2003 | 11:17 AM
speedemn's Avatar
I just got a MEVI kit and I just want to make sure that I have all the parts before I go ahead and disassemble my stock manifold.
MEVI
MEVI collector cover (covers the 6 butterfly holes)
1 x Intake gasket Nissan p/n 14032-38U00
6 x power valve Nissan p.n 14513-38U00
9 x hex bolts Nissan p/n 08050-6205A
1 x shaft assembly (rod?) Nissan p/n 14512-38U00
1 x o-ring Nissan p/n 14515-40F00
1 x power actuator p/n 14517-38U00
Harlan RPM Switch
MAP BARO switch (from GM dealership)
Vacuum canister (half-cylindrical black plastic box)
2 x 10mm bolts to bolt the power actuator to the MEVI
1 screw which is currently an orphan
1 ground wire horseshoe connector (?)
Misc. wires connected to RPM switch and vacuum canister and relay fuse
Are there any other important major parts that I am missing here? Hope someone can help me out with part #s if necessary.
Thanks.
P.S. I would like to replace all gaskets in order to avoid potential problems later. Please recommend what else I would need.
Old May 11, 2003 | 01:36 PM
pMB's Avatar
pMB
Ask Ramius83
he did MEVI.
Old May 11, 2003 | 01:47 PM
Dave B's Avatar
Not DAVEB the parts guy
You forgot JWT ECU
Dave
Old May 11, 2003 | 02:01 PM
speedemn's Avatar
Originally posted by Dave B
You forgot JWT ECU
Dave
Yeah that's in the plans. I have a spare ECU here with the same production cycle date as my car. But I am contemplating whether I should send in my own ECU since I know it is in good shape or if I should send this other ECU.
Old May 11, 2003 | 07:33 PM
aznsap's Avatar
sorry i dont' know much about this, what's the purpose of the switch? to turn on/off the mevi? what's wrong with leaving it on all the time?
Old May 11, 2003 | 07:35 PM
aznsap's Avatar
what's the purpose of the switch? sorry im new to the mevi. is it to turn the mevi on/off? what's wrong with leaving it always on?
Old May 12, 2003 | 01:28 AM
Shoooter_j's Avatar
Can't leave it on all the time, otherwise you lose massive power below 5k rpm, hence the switch.
Bump for some more input on any more needed parts....
Old May 12, 2003 | 05:11 AM
speedemn's Avatar
Throttle body gasket 14120-38U02
EGR gasket 16175-31U01
14033 - 38U00
I think one of those 2 gaskets goes in between the butterfly holes and the cover. Correct me if I'm wrong.
Old May 12, 2003 | 09:04 AM
aznsap's Avatar
ohHHH, so the rpm switch switches it on at 5k? it's not like an actual flip switch you have to manually activate, you control the rpm at which the mevi is activated?
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
jholley
Aug 30, 2015 06:39 AM
Abdelrhman
Aug 17, 2015 12:16 PM
Team STILLEN
Aug 10, 2015 04:29 PM
