What Should My Next Mod Be??
Old May 13, 2003 | 10:38 AM
SLOW96MAX's Avatar
I HAVE A Y PIPE, INJEN INTAKE AND PULLEY ON MY 96 MAX AUTO. WHAT SHOULD BE DONE NEXT FOR THE MOST GAINS ON THE LEAST AMOUNT OF MONEY?
ECU?
MUFFLER?
B PIPE?
OTHER?
Old May 13, 2003 | 12:02 PM
Joeycurl's Avatar
With all that power you should consider how your going to stop...maybe up grade your brakes. If you don't want to then I would suggest improving your handling ie RSB and FSTB.
Old May 13, 2003 | 12:19 PM
SLOW96MAX's Avatar
I HOPE YOU ARE KIDDING.
Old May 13, 2003 | 12:24 PM
geo1317's Avatar
focus on the suspension, get a RSB, FSTB, and some springs and shocks.
Old May 13, 2003 | 12:26 PM
heems27's Avatar
If I were you, I would get a MEVI with the ECU upgarde. With those mods, your Max will be pretty fast. By the way, please turn off your CAP LOCK.
Old May 13, 2003 | 12:38 PM
TheMax95's Avatar
JWT ECU, then MEVI. No need for catback. I think it's just a waste of money and not worth it for the little performance it yields. That's if you wanna go fast.
But if you wanna handle better, you definetely need a rsb and fstb. Then maybe springs, struts, and sticky tires.
-Paul
Old May 13, 2003 | 06:19 PM
Max Noob's Avatar
u need suspension work..doesnt all that body lean and roll make you feel nauseated?
Old May 13, 2003 | 10:02 PM
† ErV †
i think he just wants to make it fast in a straight line type of fast.
just nitro it...
Old May 13, 2003 | 10:25 PM
happyricefob's Avatar
V^___^V
some Z rated tires, if u can't stay on the road how the hell u gonna go fast?
Old May 13, 2003 | 10:41 PM
drewm's Avatar
Re: What Should My Next Mod Be??
ECU?
MUFFLER?
B PIPE?
OTHER?
All the parts are in the link in my sig, research research research.
Old May 13, 2003 | 10:51 PM
Dev's Avatar
Dev
no i hope you're kidding if you think a muffler is going to make you go faster.
you've done the major n/a performance upgrades...time to do suspension or brakes like someone already mentioned.
you will gain so little from the mods you mentioned.
Old May 14, 2003 | 02:11 AM
RichMax's Avatar
Boosted like Snipes tax refund
consider tranny valve body upgrade... power means nada if not used properly...
Old May 14, 2003 | 05:47 AM
maxspeed96CT's Avatar
The original VQ...
i think the MEVI and the ECU is not worth it, get nitrous or if you got the money get boost.
Old May 14, 2003 | 06:03 AM
StygianMax's Avatar
Power is useless without control of it (slight exaggeration but not far from it).
Performance springs/shocks to reduce weight transfer off your front wheels to rear ones will get more "power transfer" from engine to asphalt. Ditto with nice tires.
Investing in an effective set of brake pads is good for slowing you down when you're booting along at a good clip & some ding-a-ling unexpectedly cuts in front you & you have no "escape path".
My $0.02
Old May 14, 2003 | 06:53 AM
clee130's Avatar
Tornado Fuel Saver
Old May 14, 2003 | 06:54 AM
mzmtg's Avatar
Minister of Silly Walks
Ebay air temp sensor resistor mod.
lrb6805
Sep 30, 2015 08:12 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
