Air Bag light is flashing on and off... help!
Old May 13, 2003 | 02:03 PM
silvermax2k2's Avatar
hey guys:
as most of you know, i am selling my car to buy a 2001 AE maxima within this week. but i was driving around today and all of a sudden my airbag light on the speedo started to flash. so i pulled over and turned off my car, and then turned it back on, but it is still flashing. all day when ever i start my car the light just comes on. not only is this really anoying (i always see it in the corner of my eye) but like i said i am selling my car to the dealership very soon so i don't want them to see that light and knock alot of money off the price they are giving me.
i check my air bag fuses and they look fine. what the heck is the cause? why would it randomly just start flashing? i was not driving aggressively or braking hard or anything... any ideas? thanks...
Chris
Old May 13, 2003 | 03:54 PM
Chron!cRAGE's Avatar
I have the same problem with my maxima. There are steps on the .org to turn your key to the 'on' position and press the driver side door button 7 times within 5 seconds and then start the car or something like that to reset the light. The trick didn't work for myself..but worked for some others.
Old May 13, 2003 | 08:27 PM
do you know the exact procedure to reset the light? i really need to turn them off quickly! thanks
Old May 13, 2003 | 10:13 PM
maximalnemisis's Avatar
dude from what the mechanic at the dealer told me you cant turn the light off unless you have the right tool which would happen to be a obd scanning and diagnoses tool because the airbag is a whole separate system from the ecu......oh by the way the door light trick does not work
Old May 14, 2003 | 06:35 AM
genepool's Avatar
yes, the door light trick does work....I've done it myself.
Old May 14, 2003 | 07:05 AM
genepool's Avatar
Old May 14, 2003 | 08:13 AM
ok so how did you get your light to stop ...walk us through the process because this is what I did and it did not work; put key in the ignition, turn on ,immediately press the rubber door light thing 7 times then start car ??????? light should go off but it didnt in my case.... and I,ve tried it more than once
Old May 14, 2003 | 09:34 AM
kenju4u's Avatar
u forgot to dance around the car in circle 8 times on a full moon
Old May 14, 2003 | 10:02 AM
pocketrocket's Avatar
Open the driver's door. Note the rubber covered button, a button which is pressed by the door when the door is closed. This is the door switch.
Turn the ignition from OFF to ON. Press the door switch at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF.
Close the driver's door. Start the engine.
Old May 14, 2003 | 10:23 AM
it did not work for me. i did it atleast 30 times... and i am sure it was not good to start and turn off the engine that many time in a short period of time. but i tryed and the most i got out of it was a sore arm/hand. but the light did seem like it wanted to go away, but it still flashed. like the light did not flash as fast or in a timed order. any other ideas guys?
Old May 14, 2003 | 01:45 PM
FormorAccordMan's Avatar
NO NO NO, you don't turn the engine over! You simply put the car on the on position,Windows are able to roll up and down, where you accessories work. Now go try it. It worked for me.
Old May 14, 2003 | 03:57 PM
I tried the drivers side door trick again and the light stopped blinking! But it returned when I started up the car again . Doesn't seem to want to come off any more.
Old May 14, 2003 | 07:30 PM
japrile's Avatar
Airbag
Had the same problem with mine....had to get the airbag module replaced $$$$$$$$$$$$$$$$$$$$ bout 400 well CDN dollars.
Old May 14, 2003 | 08:30 PM
but pocketrocket says to turn over the engine once the steps are completed... i'm confussed. here is his quote:
"Open the driver's door. Note the rubber covered button, a button which is pressed by the door when the door is closed. This is the door switch.
Close the driver's door. Start the engine."
ah, what should i do? i wish i could take it to someone with out them charging me an arm and a leg. *sigh* my hopes of getting a 01 max are slipping away (i got declined for my loan too.) this bites.
maybe they will not care? or maybe they will not test frive it again! help help help help!
Old May 14, 2003 | 08:35 PM
erty67's Avatar
Decal Specialist
try this....
http://forums.maxima.org/showthread....=air+bag+light
Old May 14, 2003 | 08:47 PM
erty67's Avatar
Decal Specialist
http://forums.maxima.org/showthread....ghlight=airbag
Old May 15, 2003 | 07:25 PM
thanks Ed, always looking out for me! from what i have been reading this is not a easy or cheap problem to fix. some poeple can reset it, but others can not. they said that alot of people that have side airbags get the light alot, which generally means that the harness needs to be replaced. cost, $600. $600!!!!! wtf, this is the last thing i need right now, and it is the perfect chance for the dealer to knock off a grand off the price of the car. *sigh* my luck never changes. give me a call sometime Ed, i lost your #. ttyl
Chris
Old May 15, 2003 | 10:44 PM
erty67's Avatar
Decal Specialist
hey....$12.5k still isn't bad let me talk to a friend of mine. He used to work for Norwood Nissan. Maybe he can tell me how to get that light off.
tsi6001
Oct 3, 2022 10:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Samedi
Aug 13, 2015 04:05 PM
kirkhilles
Aug 8, 2015 10:53 AM
