what brake fluid do you use?
Old May 13, 2003 | 05:20 PM
aznsap's Avatar
for some reason i do not have permission to use the search....
anyway, what kind of brake fluid do you guys use and why? i hear that motul600 stuff is good for autoxing, but that's if you change your brake fluid often, as i hear it absorbs moisture. i will have to change my brakes soon, so i was thinking of the ATE superblue stuff, since it absorbs moisture at a very slow rate. any recommendations and why? thanks.
Old May 13, 2003 | 05:50 PM
njmaxseltd's Avatar
If you flush your fluid periodically you should be fine with just about any Dot 3 fluid.
I use GUNK heavy duty Dot 3. My fluid get flushed with every brake job.
Old May 13, 2003 | 05:54 PM
aznsap's Avatar
every brake job? do you mean when you change the pads?
btw.... how many liters/pints of brake fluid do i need to purchase if i'm flushing out my system and changing the brake lines/
Old May 13, 2003 | 09:02 PM
rmb's Avatar
rmb
Re: what brake fluid do you use?
Don't waste your money on the super-whoopie brake fluid with the stock brake system. Any regular name-brand DOT3 rated fluid is fine. I think I used Castrol last time.
I flush/refill my vehicles every 30 to 50k.....
-RMB
Old May 13, 2003 | 10:17 PM
aznsap's Avatar
Re: Re: what brake fluid do you use?
-RMB
cool thanks...... i still don't know how much brake fluid to go buy tho.
Old May 13, 2003 | 10:26 PM
AuToMaX_95's Avatar
Re: Re: Re: what brake fluid do you use?
Go to your local auto store and buy any Dot 4 fluid if you don't want to spend more than $5. After you leak your brake fluid, just top off the new brake fluid. Pump your brake and go top off your fluid again. You don't have to know extactly how much to put in like oil and tranny oil. All you need to do is top it off to the line for the brake fluid.
Old May 13, 2003 | 10:33 PM
TooMAX's Avatar
I use valvoline synpower. Cheap and compares well to the expensive stuff:
brake fluid comparison
Old May 13, 2003 | 11:09 PM
aznsap's Avatar
Re: Re: Re: Re: what brake fluid do you use?
can i do this even if i am changing my brake lines? i have never done it before, so guess i was just assuming that i would completely replace all the fluid.
Old May 15, 2003 | 06:51 AM
iwannabmw's Avatar
If you are going to autocross or drive the car hard, the ATE Superblue is perfect and well worth the money. I have yet to cook this stuff on the track. You will need to buy 2 liters.
Old May 15, 2003 | 07:27 AM
NISMO808's Avatar
I use FORD brake fluid.
Old May 15, 2003 | 12:05 PM
TooMAX's Avatar
Yes, ATE Superblue is great stuff for the bucks. (and it's a cool blue color!) The ATE TYP200 Gold fluid is exactly the same formula except that it's amber in color. Alternating colors makes it very easy to see when all the old fluid has been flushed out when changing fluid. One slight problem I've heard is that Superblue is not DOT approved(?) since they stipulate that brake fluid must be amber in color.
Old May 15, 2003 | 01:33 PM
sandman1098's Avatar
Most of the brake fluid I have seen has been clear, not amber.... I may be wrong though
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
