gauge pod wiring assistance needed
Old May 21, 2003 | 08:41 PM
JDM4LIFE's Avatar
any advise on running the wiring for my gauges? i don't wanna have to take out the dash, but trying to fish the wiring from the bottom of the a-piller down to the bottom is becoming a never-ending battle. help please i just want my a-pillar back on already...
Old May 21, 2003 | 08:56 PM
Nismo's Avatar
take off the pillar completely then you have to drill a hole from under the fender to the back of the pillar to the engine bay
Old May 21, 2003 | 10:49 PM
blackmxma's Avatar
I just did mine too....take off the front left wheel and remove the fender well lining. inside on the firewall is a big grommet you can run wires through. it comes out on the inside underneath just above the dead pedal. its easiest to just stick a clothes hanger through and pull the wires. then use the clothes hanger again to pull the wires from underneath the dash up through the side of the dash where the a piller meets it. it takes a little while to get the wire through cuz there's lots of stuff in the way, but its not real hard.
Old May 21, 2003 | 11:01 PM
WizzaMax's Avatar
I used the wires from the speaker grommet on the inside hinge area of the DS door...just pierce and pull...it takes some creative hand work to get the wire started behind the fusebox...
Old May 21, 2003 | 11:53 PM
JDM4LIFE's Avatar
thanks for the help. will the coat hanger thing work from going from getting the wire from the dead pedal area to where it'll meet the gauge pod on the a-pillar? i can handle the rest, it's just getting it through that area that's a b@#$%.
Old May 22, 2003 | 08:53 AM
BlackCat's Avatar
RIP '98 Maxima SE
What I did was run a thick wire down the hole at the base of the A pillar first until it shows up behind the fuse box. Then I taped all of the wires together to the thick wire that is still exposed at the base of the A pillar. Next I pulled the thick wire that I left dangling behind the fuse box slowly and that will pull down the bundle of wires with it. Kind of like threading a needle.
Old May 23, 2003 | 07:59 AM
JDM4LIFE's Avatar
thanks to your advice blackcat, i got it all through. now, i just have to get a few of the wires through to the engine bay. i guess i'll get the wires through the grommet that goes to the fender now. right?
Old May 23, 2003 | 10:22 AM
WizzaMax's Avatar
Old May 23, 2003 | 10:28 AM
XXXL Cracker's Avatar
I set min eup the same way blackcat is describing and ran wires through the grommet hole to the engine bay. I also drilled a hole in the clutch punch out are on the firewall ( I am auto).
Take your time and do it right cause it is a ***** if you need to redo it.
D
Old May 23, 2003 | 10:35 AM
BlackCat's Avatar
RIP '98 Maxima SE
D
I'm auto too but instead of drilling an extra hole there is a little hole by the front strut that I threaded the wires through. I had the loose wiring tucked underneath the inner wheel cover and then come down into that hole.
Old May 23, 2003 | 11:21 AM
JDM4LIFE's Avatar
well, i just wanted to run the wires through the firewall, but the power wires i just ran at the same time for my amps takes up the existing room for that kinda. it seems to be an endless battle to fit my drill in there for a new hole. where's this clutch punchout hole at? i'm trying to avoid jacking up the car if possible (mainly just cuz i'm lazy :P ) and prefer having those wires coming out the same area as my others.
smplyamzng
Dec 13, 2015 01:19 PM
TonyJr
Aug 20, 2015 12:14 AM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 13, 2015 12:50 AM
maximaham
Aug 7, 2015 01:11 PM
