R32 Projector Conversion
Old May 23, 2003 | 12:13 AM
Kanaka's Avatar
Well my R32 headlights came in today. Has anyone else done this mod? from what I see I need to make a few modifications to make them fit. If you have done this mod, please let me know if i'm doing this correctly.
Old May 23, 2003 | 06:46 AM
Axra's Avatar
Re: R32 Projector Conversion
What kind of modifications? Body or just some kind of mounting system?
Old May 23, 2003 | 07:51 AM
juani's Avatar
Rockin' VK56!!
Isn't r32 headlight too small to be on maxima??
Old May 23, 2003 | 08:01 AM
JDM4LIFE's Avatar
Re: Re: R32 Projector Conversion
i think they're definitely smaller than other skyline heads, but i'm sure you can have a body shop make some changes. it'll just be more cash for the project. i've definitely gotta see pics!
Old May 23, 2003 | 09:33 AM
Canuck's Avatar
Search for this. It was discussed last week. No real body work was needed.
Old May 23, 2003 | 10:56 AM
Jason R's Avatar
aka UNCDooD
No body work needede at all. contact sanjosemaxima. he has these installed on his car.
Old May 23, 2003 | 10:58 AM
Soon2BMaxed's Avatar
PICS????
Old May 23, 2003 | 11:02 AM
Jason R's Avatar
aka UNCDooD
Originally posted by Soon2BMaxed
PICS????
Old May 23, 2003 | 11:05 AM
njmaxseltd's Avatar
Soon2BMaxed - Very cool Sig!
Old May 23, 2003 | 11:46 AM
i just noticed that it has quotes under the ip info that change everytime the page is reloaded. last time i looked it said "There is no spoon." (quote from The Matrix)
Old May 23, 2003 | 11:52 AM
Kanaka's Avatar
Thanks, exactly what I wanted. And they are not too small to fit on the maxima. actually i took off my headlights and grill. it seems like the following need to be done:
cut inner supports of r32 lights to clear the frame behind the lights.
cut the frame behind the lights a little to make space for the inner high beam housing.
cut 3/4" of that little piece of the bumper that sticks up to meet the grill.
somehow find a way to secure corner lamp since headlight housing and stock mounting point are gone.
side bolts seem to be in the right position. also seems a bit shorter than stock lights. might put some black surgical tubing to fill the gap. but all in all it looks very close to stock headlights.
Old May 27, 2003 | 06:20 AM
Anachronism's Avatar
Please post pics from all angles when you are done if you can and tell us how long/ how much work it was to make these fit.
Are you going to have to cut the little piece of metal in between the corner light and stock headlight? Will you need some sort of custom bracket to hold the grill in place?
Thanks.
EDIT-
This is the only picI have seen of these on a Max -
The line where the stock headlight and corner light join follows the line between the hood and fender. In the pic above you can see the R32 lights do not. Was the corner light trimmed? They also look like they stick out more than the stock headlights but you would need to see a pic from the side to tell for sure. It almost looks like the upper part of the headlight is in front of the corner light in the picture
Will they line up with the stock grill?
Old May 27, 2003 | 06:59 PM
Quack 2x's Avatar
Kanaka:
Let me know if you need brackets made or bent before the school year is out. I can ask some of the metal shop students if they can make you something (they are making a gauge panel for the DIN opening in my car).
Aloha,
Quack2x
Old May 27, 2003 | 07:52 PM
ny96max's Avatar
this is an old pic that i just found on my computer:
Ant
Old May 27, 2003 | 09:47 PM
(_8*(l)Homer's Avatar
Awsome sig, Soon2B!!
Mine is not so cool
Old May 27, 2003 | 09:58 PM
BluFlame's Avatar
-Pics should be taken with the hood open, so we can see mounting points.
-some installation instructions+possible GD. Not a bad mod for $200?
psics above prove 95-96 front end look awesome.
Old May 28, 2003 | 12:29 AM
hakk97se's Avatar
Ant
those look like R34 headlights....
Old May 28, 2003 | 11:57 AM
Mine is not so cool
Old May 28, 2003 | 02:40 PM
96shogunmax's Avatar
Originally posted by slammed95
They are. Since they include corner lights, no need to align the 2 lights. Just get it done right the first time.
These need body work to get them done right
Old May 30, 2003 | 01:24 PM
98BlaximaSE's Avatar
What is the beam pattern for these things like, and what kind of bulbs do they use for hi and low?
Old May 30, 2003 | 06:00 PM
ghetto_bill's Avatar
Ant
That looks really nice. Anyone know how much the R34 headlights cost and the approximate cost for bodywork to get those to fit? Thanks
Old May 30, 2003 | 06:31 PM
hairris's Avatar
Ha Ha nice try! New the things cost like $500-$595 dollars! Expensive! Used? Good luck I haven't seen them anywhere?
Harris
Old May 30, 2003 | 06:41 PM
iansw's Avatar
Just realized.....that looks like an I30 hood - (notice the creases)
KabirUTA13
19
Oct 17, 2015 02:15 AM
Calabar
Oct 5, 2015 09:57 PM
Vistance
Sep 17, 2015 05:17 AM
kjlouis
Sep 14, 2015 11:22 AM
Hdnseek
Sep 9, 2015 05:55 AM
