Water Leak in Passenger Cabin
Old May 28, 2003 | 06:02 PM
jgray's Avatar
Got in my car last week after a heavy rain and notice front and rear carpet on passenger side was soaking wet. Pulled back the carpet and discovered a small lake. I can't figure out where water is coming from. I've got a sun roof, so today I opened it up and peered in. I noticed water collecting in the front right corner of the sun roof. I also saw what appeared to be a "weep hole" in the corner that was clogged with small leaves and dirt.
Am I correct that this is a weep hole that has backed up causing water to enter?
Appreciate any advice/help.
thx
Old May 29, 2003 | 12:04 PM
bhmax's Avatar
I'm having a problem with water also. It's only collecting UNDER the passenger side mat. The carpet on the mat itself is not wet at all. Just haven't gotten a chance to check it out yet. Anyone experience something similar?
Old May 29, 2003 | 12:09 PM
njmaxseltd's Avatar
Re: Water Leak in Passenger Cabin
Yes
Old May 29, 2003 | 05:34 PM
jgray's Avatar
How do I clear it, and do you know where the water exits from?
Old May 29, 2003 | 08:45 PM
klymkow's Avatar
The sunroof has drain hoses on both the rear left and right sides. There are tubes that run from the sunroof frame down the rear pillars behind the rear wheel wells and out the bottom of the car.
The right side hose connects into the drain fitting for the antenna.
You can probably try blowing some air up through the hose or run a stiff wire up through to clear it out.
Tim
Old May 30, 2003 | 12:03 PM
jgray's Avatar
Thanks Tim, I'll give it a try
captchaos
Mar 15, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
The Wizard
24
Oct 1, 2015 08:47 PM
RWCreative
Sep 21, 2015 11:01 AM
Hdnseek
Sep 9, 2015 05:55 AM
