Size of Gas Tank in Gallons
Old May 30, 2003 | 10:33 AM
quiksand's Avatar
I've tried to use the search function but it tells me I'm not authorized to use it.
Here is my question. How many gallons of gasoline can our tanks hold?
Any help is appreciated.
Thanks.
Old May 30, 2003 | 10:40 AM
Ramius83
If I remember correctly, our tank is an 18.5 gallon tank.
Old May 30, 2003 | 10:44 AM
SonicDust187's Avatar
18.5 Most I ever filled my car was with 17.9 gallons.
Old May 30, 2003 | 10:46 AM
quiksand's Avatar
Thanks alot, I thought the same thing. I was calculating my gas mileage. I went 373 miles on 14.5 gallons which comes out to roughly 25.75 mpg. I drive about 65% Highway 35% City.
Old May 30, 2003 | 11:22 AM
bananamax's Avatar
19 including filler neck and lines/ filter.
Old May 30, 2003 | 01:13 PM
KsuMax's Avatar
Cheesing away...
Why would you count those, by the way its 18.5
Old May 30, 2003 | 01:32 PM
supercobraz's Avatar
Whatever the size is, I'm happy to say that I just came back from vaction and I was able to drive from Austin,TX to New Orleans,LA on one tank of gas with a few miles to spare. That was a distance of 515 miles from gas station to gas station I then put 17.5 gallons back into the tank. I always over fill my tank until is overflows. To me that's the difference of almost a hundred highway miles...29 miles a gallon..not too shabby
Old May 30, 2003 | 01:41 PM
quiksand's Avatar
I live in New Orleans and I've made it to Houston with the gas needle just under half. After it drops past half a tank gas seems to go faster for some reason.
Old May 30, 2003 | 01:46 PM
dwapenyi's Avatar
I always overfill my tank as well, but not by much. Isn't there a concern that over-filling may damage the emissions stuff because the over flowing gas will go right to your charcoal canister purge control system etc
DW
Old May 30, 2003 | 01:47 PM
Yeah I've noticed that. I at least 120 miles down the road before the needle makes it back to F. You would think you are going to get 600 miles on that tank. Once the needle drops to the E and just below it, you are very close to having an empty tank. I have filled my tank with 18.3 gallons before.
Old May 30, 2003 | 01:52 PM
DW
I know some say not to do it but I thought it was because it's dangerous because of the pressure. Not sure about the emissions stuff you mentioned.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
ef9
Oct 4, 2015 08:43 AM
