My New Setup
I think I'm gonna go Stillen S/c intercooled. My friend's benz is S/c intercooled.
Anyone have any info on this setup. Is the IC really worth anything. I figure when you're going 80 MPH a lot of air will effectively cool down the charge.
I've read the Vortech literature that came with my S/C and it mentions that they have available some racing application that allows you to put ice water so that it cools down the inpipe. The Stillen catalogue shows only an intercooler for the 300ZX but nothing for the Maxima, so you'll probably have to get one custom built.
Can someone please explain to me exactly what an intercooler does?
Does it cool the air, or the turbo?
Does it use liquid running through it like a radiator or air?
Please, I haven't been able to find any good info on this.
Here's what Sport Compact Car Feb. issue says " Compressing air makes it hot; this is an inescapable fact of nature. The more efficient the compressor, the less it heats the air, but the heating still occurs and it is still significant. Cooling that air before it goes into the engine can have a profound effect on performance." An engine runs better with cold air than hot thus the intercooler was created.
Cold air has a higher pressure than hot air. When cold air is drawn into engine for compression, it produces more power. By cooling the air, either in turbo charged, supercharged, or naturally aspirated engines will more or less increase the horsepower. An intercooler can be thought of as a radiator, only it cools air, not water.
I dunno about the Lotus just now. I figured having two cars, two insurance bills, etc. Rigth now I'm just gonna make the Maxima FAST as hell so I have no desire for a fast car.
The amount I can spend to make the Maxima insanely fast isn't all that much.
Plus the shock people go into when they see how fast my Max is now is priceless. I can't wait to see the faces with teh SC
Post some info once you get the s/c intercooler combo Brian
In reply to some earlier posts about how the intercooler works http://www.howstuffworks.com is a great site for learning. It breaks everything down into basic components, and they have everything from how your engine works to LSDs, cams, spark plugs, forced induction, etc.
-hype
In reply to some earlier posts about how the intercooler works http://www.howstuffworks.com is a great site for learning. It breaks everything down into basic components, and they have everything from how your engine works to LSDs, cams, spark plugs, forced induction, etc.-hype
Ahhh, not really....
By cooling the air after it is compressed, higher boosts can be used which means more oxygen-fuel-power.
I know how an intercooler works. I know how a supercharger works. I know the differences between that and a turbo. I didn't ask the questions. I just simply wanted to know if people thought the itnercooler would be beneficial with the supercharger. Since the supercharger is belt driven and not exhaust driven it's not going to be as hot. I was just trying to see if anyone had any experience?
I believe Vortech makes...
an aftercooler. Same function as an intercooler, except it uses water to cool the air before the throttle body, or is it the MAFS? I once looked into getting a custom intercooler done. The design of the Stillen kit would easily allow for a front mount intercooler, HOWEVER, you would need a pretty slim intercooler to dop a front mount set-up. There isn't much room to work with and it's expensive to do.
In all hoensty, I would geta custome cold-air intake for the S/C before going for an intercooler or aftercooler. More bang for the $$$
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
CAN-Toronto FS: Emanage Ultimate and plug/play Harness
knight_yyz
Nov 6, 2015 02:34 PM
KabirUTA13
19
Oct 17, 2015 02:15 AM
