Spongy Brake Pedal. Urgent!!!
Old Jun 3, 2003 | 03:52 PM
imported_2_tha_max's Avatar
Hey Guys,
I installed new rotors,brake pads and metal brake hoses. I have bled the brakes and have checked all connections to make sure everything is tight. Everything was working fine before I made any changes. I took the car to a nearby pep boys. The mechanic said whenever You break pressure on the brake lines for a nissan maxima you have to change the master brake cylinder. I don't believe him. I would appreciate any help in this subject.
Old Jun 3, 2003 | 04:06 PM
Old Jun 3, 2003 | 04:14 PM
drewm's Avatar
Re: Spongy Brake Pedal. Urgent!!!
Originally posted by 2_tha_max
Hey Guys,
the mechanic is full of S***
As long as you bled the brakes enough and properly while filling up the brake fluid reservoir, then it shouldn't be spongy. Keep bleeding it until the pedal feels stiff.
Old Jun 3, 2003 | 04:32 PM
TooMAX's Avatar
Hey Guys,
Neither will anyone else reading this.
Old Jun 3, 2003 | 05:24 PM
rmb's Avatar
rmb
Hey Guys,
LoL....
You still have air in the lines. But don't have this idiot bleed them or I'm gonna guess you will "magically" need a new master cylinder.....
Bleed em yourself. Even without a lift or a vacuum bleeder it's an easy 1-2 hour job with a friend.
-RMB
Old Jun 3, 2003 | 05:27 PM
asf4life's Avatar
bleed them with the car on, and extra help, i tried to bleed mine with the car off, liek the chilton says, but it doesn t do jack ****, so have teh car on but use the same procedure and have some extra set of hands
Old Jun 3, 2003 | 07:02 PM
Thanks guys I will definitely try to bleed the brakes again.
Old Jun 4, 2003 | 06:05 AM
thanpto's Avatar
Why does the car need to be on? I don't remember haynes saying anything about having the car on during this process.
Old Jun 4, 2003 | 10:10 AM
sandman1098's Avatar
So the Brake Booster can help out..........
Old Jun 4, 2003 | 10:13 AM
dave harms's Avatar
Bleeding
If you need the car on to bleed the brakes, there is another issue. You only need the extra pressure when trying to stop a few thousand pounds, not when pushing juice into a bottle.
I don't know what technique you use when bleeding, but it's best to do it into a bottle with a hose, this way if you do pull fluid backwards by accident, it will not pull any air.
Look at the lines under the car, some will have to be bled a lot longer than others.
Keep the resevoir very full when pumping. When it gets low, you may pull air in (like a sink drain can, even when the water is over the drain).
I've always done my own brakes (caliper replacement, etc.) and it doesn't need to take more than 1/2 hour for all 4 lines. (with a friend that listens)
Good luck!
dave h.
Old Jun 4, 2003 | 10:14 AM
hacim105's Avatar
I didn't need the car on, mine worked just fine and so did sean97se when we did his breaks.
Like everyone said you have air in the lines. Just make sure you bleed them in the proper order and you should fix your problem.
1. rear passenger side
2. rear driver side
3. front passenger side
4. front driver side
Old Jun 4, 2003 | 10:18 AM
asf4life's Avatar
but leaving ur car on makes it go a lot faster
Apr 16, 2020 05:15 AM
ef9
Oct 4, 2015 08:43 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
