speed governor question...
Old Jun 8, 2003 | 05:34 PM
rwatt1981's Avatar
Hey guys, I'm about to remove the speed governor out of my 98 GXE and I have only one question. Will the CEL be on all the time when I cut the wires? If so, how long will the CEL stay on for?
Thanks!
Old Jun 8, 2003 | 05:40 PM
niksal's Avatar
i too have a ques. does my 99 gle have a speed governor? thanks .. sorry about taggin on your thred rwatt1981
Old Jun 8, 2003 | 05:41 PM
ch13f's Avatar
Yeah, if you are removing the limiter by cutting the wire on the ECU then yes, the SES light will be on all the times.
Old Jun 8, 2003 | 05:44 PM
sandman1098's Avatar
The GXE is the only Maxima with a speed govenor..... The GLE and SE's dont have it....
rwatt1981's Avatar
That's what I was afraid of. Oh well, I'm going to leave it alone I guess.
Old Jun 8, 2003 | 05:46 PM
rwatt1981's Avatar
No problem niksal
Old Jun 8, 2003 | 05:53 PM
ch13f's Avatar
I think if you wire it to a switch and only use it when doing 120+ the SES won't have time to come on, just make sure to flip the switch back when ur done trying to kill urself.
Old Jun 8, 2003 | 07:31 PM
Swap ECUs from the same year Maxima SE or GLE..... lol...... but the price of a new ECU aint worth it though
Old Jun 8, 2003 | 08:26 PM
ZuMBLe's Avatar
Re: speed governor question...
Wire a switch to the CEL. Leave it off till you want to pull codes.
Thanks!
Old Jun 8, 2003 | 11:10 PM
ORBRIT's Avatar
Wiring a switch is easy - when you cut the pink/blue wire, just solder the ends to longer wires and run them through a toggle switch.
In the on position, the switch allows the current to pass, so you don't get a CEL.
In the off position, the circuit is broken and you can go faster than the speed limiter allows.
The CEL only comes on after about 15-20 minutes of driving with the speed limiter circuit broken.
Here's where I put my switch. (the red thing next to the fuse box panel)
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
