ground control is bouncy....
Old Jun 8, 2003 | 07:32 PM
mayhemI30's Avatar
"I'm running with scissors!"
if i got different shocks would it git rid of the bouncy feeling. what shocks would you guys recomend to run w/GC???
Old Jun 8, 2003 | 07:41 PM
carnal_c30's Avatar
Former Sponsor
Konis
Old Jun 8, 2003 | 08:09 PM
95GreekMaxSE's Avatar
your struts aare probly blown. new struts OEM or aftermarket but would also need shocks aswell and the mounts.
Old Jun 8, 2003 | 08:45 PM
drewm's Avatar
Re: ground control is bouncy....
http://drewm.dyndns.org/~drew/maxfaq...aximaCoilovers
Due to the high spring rate and low drop they should be paired with Koni Yellows, KYB AGX, or Tokico Illuminas. Ground Control recommends that they only be paired with Koni Yellows.
Which can be found here:
http://drewm.dyndns.org/~drew/maxfaq...p?MaximaShocks
Old Jun 8, 2003 | 09:11 PM
waveridr85's Avatar
yo, i noticed you have changed the stall on your torque converter. how did you do that? where did you buy the partd? was there a significant difference? how is it for normal driving thanks. sorry to thread *****
Old Jun 8, 2003 | 10:38 PM
mayhemI30's Avatar
Re: Re: ground control is bouncy....
will this get rid of the bounciness or will it always be like that???
protorque converter i got from jeff at maximum tuning.
everyday driving is fine. it's when you step on it out of the hole it revs up to 3100rpm before it takes off or you can torque brake it and hold the tach at 3100rpm. either way it takes off like it is mad at the world. it's kinda a dr. jekyl/mr. hyde sorta thing
Old Jun 8, 2003 | 11:21 PM
drewm's Avatar
Re: Re: Re: ground control is bouncy....
as long as you set them correctly like the page says, then yes you will have no bouncyness at all.
Old Jun 9, 2003 | 12:10 AM
Dev's Avatar
Dev
well the springs are still very stiff...so the ride still won't be like stock, but new shocks will be able to dampen the high springrate adequately.
i have gc's on stock shocks too...i feel your pain
Old Jun 9, 2003 | 12:19 AM
cerumo's Avatar
I've always thought 1 is the stiffest one. everytime I set it to 4, it is so soft and bounces.
Old Jun 9, 2003 | 02:01 AM
drewm's Avatar
It probably feels soft on 4 because it feels a lot smoother, as in the shock is actually doing more work resisting the spring. Like everyone else learned in another thread, the ride actually IMPROVES when you turn up your shocks.
The information on that page was obtained directly from an email from an KYB employee, so I'm pretty sure it's correct.
Old Jun 9, 2003 | 10:40 AM
mayhemI30's Avatar
Re: Re: Re: Re: ground control is bouncy....
do you think that they would work good with KY^B AGX?
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
