D@mn leaking front clears! What to do?
Ok...I had my fugly yellow turn signals on the front changed to clears...pretty right?
Right! Anyways...ever since they were installed I have had a problem with H20 seeping in (but only on the passenger side). I have taken it out, completely dried it, reinstalled (sealing with caulk) and it is still getting water into it!
So I am imploring all of the Maximaniacs out there to help me get this crap to stop...It is ruining my appearances!
Same w/my passenger side, though I've been too lazy to pop it back out. So you can take it apart easily?
Have you double and triple checked for small leaks?
I'm trying to think of some way to check leaks that would work on those...gotta be someway you can use canned air to help find 'em...
Originally posted by 95GreekMaxSE
what whould you use to stop the leak???
CRY!
sux, im planning on getting clear corners next pay check. is it always PITA like this with the clears??? Where can i get caulf from and wat is caulk???
Caulk...you can get it anywhere (Wal-Mart, K-Mart, AutoZone) I would use an automotive caulk (I have used the regular house caulk that was suppose to seal plastic and we see how well that did the first time
). It comes in a tube that you squeeze out (I used a caulk gun) but I am fairly sure that you can buy the kind that you can use without buying a caulk gun (it is just a mechanism to get the caulk outta the tube anyways). You apply it kinda like glue (real simple stuff man). I would wait to see if your clears even leak before worrying about the caulk issue though.
that would suck if i ahd to use caoul >ie changing the blulbs when they dies. but i guess some corners when made are slighlty off the size of thge stock conrers either to small or to big letting water in. DC i know usually dont leak cause are made right on scale. EBAYS i guess are prone to leaking. thanx for your help. (btw... born greek ;-) )
) I have Diamond Cut clears (not from Ebay)...maybe I just got a sucky set! OH Well...
Originally posted by BlackSE5spd
(ooh, even better
(ooh, even better
Originally posted by MdMaxDrvr
I've had my clears for 2 years now with no problems. I seem to recall that at some point there was a bad shipment of clears from wherever (Japan maybe?) that were not made the same and had leaking issues. I think Custome Maxima had a shipment like that at one point and sent them back because of it. I could be wrong though it was a while ago. Its possible you got a set of those ??
I don't know what you guys are talking about when you refer to 'caulk', but I used clear weatherproof silicone sealant to seal up my clears. Apply a nice thick bead to the housing/lens joint and you should be good to go. The dried silicone also helps prevent those things from rattling around in the bumper recess...makes 'em fit nice and snug.
Originally posted by sbslacker
I don't know what you guys are talking about when you refer to 'caulk', but I used clear weatherproof silicone sealant...
That is exactly what I am referring to when I say "caulk"....just didn't know how else to explain it, I have always heard it referred to as caulk (maybe it is a southern thing?)
carguy96
20
Feb 6, 2021 06:21 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
