Mandingo.......
Mandingo.......
That is what I am and yersterday I tried to remove my tire in order to put the spare on and I could not acomplish this WTF. The damn bolts were on so tight that I was dam n near lifting the back of the car of the ground and now I am scared. Has anyone else had this problem? I remember hearing about a spray that would help losen them but the mo fo's are on tight as he11
hehe easy solution.....get a pipe about the size of you arm in length and make sure the width is big enough to slide into the wrench(or whatever you call it) get them loose by holding the end of the pipe...the longer the pipe the more power you will have in your hands...sometimes if a mechanic changes wheels they use the air pressured guns to get the lugs on and overtighten them...really hard to get them off without the air gun.
