alignment kit/ camber bolts
has anyone done an alignment using Eibach alignment kit or camber bolts??? its suppose to be EZ camber alignment or somethin.. but i havent found any post about anyone doing and alignment using this kit to fix the camber??? can anyone help?
DiZ
DiZ
peobably cus you don't need it if you have sprints. Anything lower you might need it like if you are going 3" lower. I bought those eibach camber bolts and they are still sitting in the box brand new cus didn't need them according to the alignmet results.
Exact same thing as the two posts above. I have them on my car just so that I could perfect my alignment, but they really are not necessary and have not made any differences to my car so far.
-Cyrus
-Cyrus
camber
Your question is something that I would like to find out more about too. Because I am planning on lowering my 99 Max and I was wondering if using camber bolts were the way to go and would I have to install them before or after I install my Sprint springs that would lower the car 2".
NO YOU WILL NOT NEED CAMBER BOLTS OR PLATES WITH ANY SPRING (note: I didn't say coilover or air suspension) AVAILABLE FOR THE 4TH GEN MAXIMA UNLESS YOUR SUSPENSION IS ALREADY BENT (in which case lowering can exasterbate the problem).
-Cyrus
-Cyrus
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
