Compression Test w/rough idle...
Ok. The dealer i took my car to the other day got on the phone with me and we went over the specifics of my car, the car they spent 15 mins with and turned up my fast-idle screw. Here what ive found out.
My Car also had a compression test by the computer.
Cyl-bank1 -65
Cyl-bank2 -27
Cyl-bank3 -64
Cyl-bank4 -66
Cyl-bank5 -106
Cyl-bank6 -107
Obviously there is something wrong with this situation. Cylinder banks 1 through 4 had very bad comression, Mechanic advisor said this could be due to a vacume leak . The Dealer also Agreeded to Look at this car once again and possibly test for some vacume leaks. I did somewhat tell the dealer i would go farther w/ this $96.00 for 15min charge they did last week so thats the reason they are willing to look at it again for free.
This shows how much power i think some of us are losing due to a rough idle. I wish finding the problem was easier though.
Cyl-bank1 -65
Cyl-bank2 -27
Cyl-bank3 -64
Cyl-bank4 -66
Cyl-bank5 -106
Cyl-bank6 -107
Tell them to use a real compression tester (the one that hooks into the spark plug) and test again. That would eliminate the vacuum varible. How is the power? Good? if so, those readings are probably inaccurate
1) tell them to use a spark plug tester to get REAL compression results
2) then after reviewing the results search for the vacuum leak manually or use carb cleaner etc.. to find the leak.
If the power is down and if your compression might be indeed bad, indicating alot of problems(ie.. torched rings).
Originally posted by bobjohnson
where can i get one of these REAL compression testers. Can you rent one from say auto-store.
tarun900
19
Dec 20, 2021 06:57 PM
knight_yyz
Nov 1, 2015 01:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
