ok have some questions
Old Jun 20, 2003 | 04:46 PM
rcracer1973's Avatar
where can i get a good price on factory fog lamps. need help with a code 1302. and what about my weak a/c system it blows cold when moving and gets warm while sitting i have a set of maninfolds to check the charge and both fans work and no leaks
Old Jun 20, 2003 | 06:12 PM
slizan99's Avatar
http://vbxmaxima.8m.com/ecudecoder.html
Old Jun 20, 2003 | 08:29 PM
ok it says MAP/BARO SW Solenoid/valve is it the sensor or the solenoid
Old Jun 20, 2003 | 08:36 PM
Max Noob's Avatar
ac might be getting low.. your ac pumps with engine power. faster your are going, the more effcient the ac is pumped and blown into your cabin. i think everyones is like that to a certain degree.
Old Jun 20, 2003 | 08:42 PM
drjohnnyfever's Avatar
Mine was pretty weak and I recharged it and it works real good now. It cools my Superblack w/ black leather down real quick here in Tampa FL, I am quite impressed.
Old Jun 20, 2003 | 08:47 PM
i did recharge it but still the same it works great when its below 85 but when its around 90degrees it doesn't get that cold
Old Jun 20, 2003 | 08:54 PM
are you using it on recirculate? There is a big difference in mine on cool days and hot days but once it gets going it gets real cold on recirculate.
Old Jun 21, 2003 | 04:05 AM
Max Noob's Avatar
ur suppose to use recirculate when using ac.. having it on fresh wastes ac, u get warmer air and someoen told me your car has a higher chance of overheating given bad conditions..
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
