Oil leak in strange place - assistance needed
Old Jun 21, 2003 | 08:12 PM
iansw's Avatar
Well, I thought I had an oil leak on my SC oil return plate.
So today I removed the SC (threw a smaller pulley on while I was at it) and looked around.
There are no leaks where the SC bolts to the enging..not the return plate, return hose, timing chain cover, etc...
But I did find that there is an oil leak in a strange place.
I can't physically see it from any angle, but it appears to be on the far left side of the valve cover, but not at the valve cover itself. More UNDER the valve cover area, dripping down directly on the top of the driver's side of the alternator....just to the pasenger side of the exhaust manifold. Just above where what I think are steel coolant lines going underneath the front of the engine.
Anyone know what is in that area that could leak oil? The valve cover gasket appears to have no leaks...this is physically below that. Is there another gasket down below there or anything?
Thanks!
IanS
Old Jun 21, 2003 | 09:46 PM
Lonely Driver's Avatar
Head gasket is below the valve cover gasket.
Old Jun 21, 2003 | 10:45 PM
iansw's Avatar
No coolant in the oil that is leaking - so I don't think it's that.
And the car runs perfectly.
IanS
Old Jun 22, 2003 | 03:33 PM
iansw's Avatar
Anyone?
Old Jun 22, 2003 | 09:37 PM
iansw's Avatar
ttt
Old Jun 23, 2003 | 08:19 PM
iansw's Avatar
well, the leak is getting worse. A few days ago it was a few drops per day - now it's morel ike 100 drops a day.
Also, I had a leak back at my oil T feed line for the SC. THe oil appeared to be coming from the Oil Pressure Sending Unit - replaced it and tightened the T even more onto the oil pan - and now it's worse too!
Anyone have any suggesstions?!
Old Jun 23, 2003 | 09:25 PM
MAXINXS's Avatar
I think some pics of the exact location would help alot if you can post some.
Old Jun 23, 2003 | 09:52 PM
iansw's Avatar
I can't physically find it - but I can show pics of the general area.
In the inderside shot, you can actually see a spot where it's dripping from.
I also have an oil leak at the SC Oil T behind the oil pan....I am aware of htis, but have replaced all components and not fixed it yet...I'm working on that.
This is ONE day of leaking
Picture from the side (looking towards driver's side - sc plate in picture on the left.
Under the car as best I could without jacking it up: (notice the drip in middle of pic - yellow circle is area it appears to be coming from)
Old Jun 23, 2003 | 09:56 PM
iansw's Avatar
Last pic - from the top, I arrowed the area it appears to be coming from. Because the pic is 2 dimentional, let it be known that I mean not the valve cover gasket, but about 8 inches below that and towards the back of the engine (further in)
IanS
Old Jun 23, 2003 | 10:00 PM
Usually when the head gasket fails, the coolant will go into the cylinders. Sometimes it may only cause either oil or coolant to leak externally. But I think it's below the alternator so forget it. How about the timing cover?
IanS
Old Jun 23, 2003 | 10:03 PM
iansw's Avatar
This is definately directly above the alternator - whatever it is.
Also - I cahnged the oil completely and saw no evidence of coolant internally either.
The timing cover I thought would leak on the other side. left side of engine where the SC is. Thinking it was the SC oil return line, I took the SC completely off and the timing cover appears to be as dry as a bone.
COuld the cover leak on the other side?
Old Jun 24, 2003 | 02:09 PM
iansw's Avatar
Old Jun 24, 2003 | 07:13 PM
MAXINXS's Avatar
Could it be the rear main seal or the engine oil pan?
Old Jun 24, 2003 | 08:50 PM
Maximum96's Avatar
i think i had the same problem, there are 2 plates with 4 bolts on each of them. One to the left of the engine mount and one to the right of the engine mount. U know, the mount near the power steering...instead of a gasket, there is silicone sealant, unbolt, pop them off and reapply high temp silicone sealant and bolt back if the leak is coming from there..
Old Jun 24, 2003 | 09:25 PM
iansw's Avatar
I htink you are talking about the Oil Plate.
That entire side of the engine is as dry as a bone.
This is under the front of the engine....a few inches up and to the left of the front header bank.
I don't think it is the rear main seal. I thought that was on the back side near the firewall. Maybe I'm wrong?
IanS
Old Jun 25, 2003 | 12:53 PM
iansw's Avatar
Checked the leaks again this morning.
Only a couple of drops.
I haven't driven the car whatsoever, so that tells me these leaks are only under pressure.
Ideas anyone?
Old Jun 25, 2003 | 01:05 PM
Jeff92se's Avatar
I'm needing a caw
Front cover timing component leak? You won't know if there's a small leak from the headgasket into the oil w/o having it analyized by Blackstone or similar. Only a massive failure will make your oil look like a milkshake.
Old Jun 25, 2003 | 01:33 PM
iansw's Avatar
You know more about engines than I do, Jeff.
Got any time over the next few days?
Old Jun 25, 2003 | 01:38 PM
Jeff92se's Avatar
I'm needing a caw
Maybe tonight. I won't be home until 8:00ish though. Gotta pull parts from the wrecker at my parent's place and cook them dinner.
smplyamzng
Dec 13, 2015 01:19 PM
rtirbany
Sep 8, 2015 11:46 AM
TonyJr
Aug 20, 2015 12:14 AM
maxinout93
Aug 16, 2015 07:25 PM
acw
Aug 13, 2015 12:50 AM
