Does it matter if i dont put 30 lbs tq on the fstb?
Old Jun 22, 2003 | 01:23 AM
Ludacris's Avatar
Dont have a torque wrench so just tightened it as much as i could with a ratchet and in 6 days its still as tight as before...what is the point of the 30 lbs of torque?
Old Jun 22, 2003 | 11:06 AM
z32drifter's Avatar
...lol....30 ft/lbs is not that much torque you can do that easy with a ratchet or wrench the idea is not to break the bolt off
Old Jun 22, 2003 | 07:51 PM
ivelweyz
The theory is that you fasten til it's pretty tight and then do a 1/4 turn...
Old Jun 22, 2003 | 10:00 PM
joew's Avatar
get it from ebay. it' ~$30.
Old Jun 23, 2003 | 01:12 AM
CaLSoNiC
If its too tight you might rp the threads off when you corner really hard. If its too lose you might lose a bolt, then lose your ****.
Old Jun 23, 2003 | 05:26 AM
mzmtg's Avatar
Minister of Silly Walks
Eh...maybe not...
Dont worry about it.
Old Jun 23, 2003 | 06:19 AM
njmaxseltd's Avatar
Your not supposed to preload the FSTB. Studies show it sees more pull out from the strut towers then push inward. Preloading it will only push the towers outward even more, not good.
The FSTB should only be seated on neutral with no preload so it braces the towers from movement in any direction.
The 30-35 ft/lb torque spec is for the 3 upper strut mount nuts.
Mar 12, 2020 12:06 AM
bryants95max
Oct 2, 2015 12:52 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
mix master
Sep 7, 2015 08:28 PM
mix master
Sep 4, 2015 05:50 PM
