key got stuck on ignition.. help
Old Jun 22, 2003 | 01:49 PM
maxspeed79's Avatar
well, subject says all. Tried search but didn't see anything useful.
I tried to take out my shift ****, so I put gear in N. After I finished with swapping shift ****, I tried to get the key out but it's stuck and can't take it out. It moves around ignition just fine, start car, turn on battery and off. But it wouldn't come out.
Any possible reason that it won't come out? Any possible way to take key out or do i have to replace ignition? Thanks in advance..
Old Jun 22, 2003 | 02:11 PM
imlikewoe's Avatar
Re: key got stuck on ignition.. help
This used to happen in my 3rd gen. Just grab a hammer and lightly hit the key back and forth while your pressing the unlock button. It'll let go.
Old Jun 22, 2003 | 02:39 PM
TheNip73's Avatar
Is it an auto??? and try putting it back in park. the key won't come out if the car is not in park. Maybe you thought you were in park, and weren't. It's happened to me before....
Old Jun 22, 2003 | 06:34 PM
Spectre's Avatar
This happened to me when I was turning off the car and my friend was messin around with the door locks. I couldn't take it out or start the car but the stupidest idea came in mind and it worked, prolly by mistake but anyway we resest the memory and than somehow it worked fine.
Old Jun 23, 2003 | 12:14 AM
Prolepsis's Avatar
My grandma's CTS has similar symptoms. I figured out that the problem is that the shifter isn't quite locked into park. Giving the shifter a gentle forward nudge is enough to lock it in and release the key. That might work for you too.
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
