CAI question
Old Jan 31, 2001 | 07:18 AM
Wayne
Finally got my CAI yesterday. I have a question where did you guys get the hole saw? And is it 3.5 how much is it,I want to be sure I getting the right thing, also is there anything else I need to install this?
Old Jan 31, 2001 | 09:55 AM
ereet's Avatar
I believe that the tube is
3.25" in diameter. I took a ruler to the thing, and it came up as 3 1/4" .... That's a tight fit though, so I'd assume the reason people use a 3.5" is for the little ring & just a little bit extra give when putting it in. I haven't drilled the hole yet, and am still using the intake attached to the MAF. The place I went to for it wanted something like $18 Canadian (like $12 US) + another $20 for some kind of adapter for it.
Other than that, a socket wrench set, and acouple of screwdrivers and you should be good to go.
Old Jan 31, 2001 | 03:56 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
the tube is 3" and you need to cut a 3.5" hole...this is because the tubing enters the wheel well at an angle...the only tools you'll need is the hole saw and the usual tools one would have in a toolbox...good luck..
Old Jan 31, 2001 | 06:36 PM
sinewave's Avatar
I borrowed a friend's 3" hole saw to install mine and two other CAI's for local Max owners. It worked o.k., except there is not enough room to install the black rubber hole liner that TPR includes in the kit. You don't really need it because the tube doesn't move around.
FYI, with the hole saw I borrowed, I needed a 1/2" drill, the chuck on a 3/8" drill was too small.
Old Jan 31, 2001 | 06:55 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
i hope you sprayed some clear silicone or sealant on the bare metal then...moisture = rust in the long run...
Old Jan 31, 2001 | 07:14 PM
Dan 93 SE's Avatar
Cutting hole for CAI
Whan Dallas and our shop foreman did mine, they used a plasma cutter. Took about 20 sec. I couldn't look, had to walk away. It worked well, smoothed it out with a dremel tool. If you don't want to mess with it, find some one with one of these bad boys.
Old Feb 1, 2001 | 05:27 AM
Wayne
Thanks for all the help. Doing it this saturday wish me luck!
Old Feb 1, 2001 | 06:30 AM
ny96max's Avatar
Buy the hole saw at Sears Hardware, cost me like $16 for the 3 1/4" one, make sure you have a drill with a 1/2 chuck cause it dont fit into the standard 3/8 drill. Takes literally 5 sec to make the hole. goodluck!
Unclejunebug
Apr 2, 2016 05:42 AM
Sep 27, 2015 08:37 AM
Socalstillen
Sep 26, 2015 12:01 PM
