throw out bearing, oem vs act
Old Jun 30, 2003 | 12:05 PM
skeelo34's Avatar
Last night, as I backed out of my driveway, I had lots of clutch chatter, and soon I heard a crunching sound and my clutch fell to the floor. One of the hinges on the throw out bearing broke and I guess when I pressed the clutch it touched the spinning pressure plate and flew right off. Bearing flew back so far that it blew out my slave cylinder (b/c of the fork that there). I pulled the tranny, some of the teeth on the pressure plate were scratched up but nothing broken.
Anyway, question is, should I put in this used OEM bearing I have (it appears fine), unknown milage, I'd say it has at least half life left, or should I get a new ACT bearing, or new OEM bearing. The bearing I had in was the one that came with the ACT clutch. I don't see why it failed only after about 8k miles of driving. Is there even a major difference between the two? Cosmetically, they are almost identical. Any input? I'm starting to get frustrated with these damn ****ty nissan transmissions.
Old Jun 30, 2003 | 12:56 PM
ejj's Avatar
ejj
Doesn't the ACT clutch use an OEM bearing? For some reason I thought it did...I'll have to look at mine when I get home.
Old Jun 30, 2003 | 01:16 PM
skeelo34's Avatar
Look almost the same, identical in size, but oem had like a hexagonal ingroove on the bottom, the act was just plain flat.
Old Jun 30, 2003 | 01:18 PM
Jeff92se's Avatar
I'm needing a caw
Just buy an OEM bearing. You know it's a quality piece. I bet the chattering stresses the to bearing ears and it finally broke. I would consider getting the flywheel resurfaced.
litch
123
Jan 4, 2024 07:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
Andy29
Sep 29, 2015 05:32 AM
